3 in 1 Machine - How Do You Move This 507 lb Machine?
MAC3-1
Re: 3 in 1 Machine - How Do You Move This 507 lb Machine?
Post by MAC3-1 »
Thank you , I dont see an attachments ?
Torch
Post by Torch »
Under the edit box should be a couple of tabs. Default / first tab is "Options". The adjacent tab is "Attachments". Click that and then click "Add files" then browse in the subsequent pop-up window to your images on your computer to select and add them.
Edit: I think you have to select the full editor first, not use the quick reply.
Thanks for your comments, Torch. I had overlooked the fact that there is a Quick Reply box. One must be using the Full Editor and Preview in order to add attachments (images).
georgere1
Post by georgere1 »
To pick it up and move ot a short distance, use a hydraulic engine crane, if you must move it very far, put it on a cart with HD wheels, and use the crane again to set it in place.
