2-1/2" NG class A shay.
mikeminton
Re: 2-1/2" NG class A shay.
Post by mikeminton »
I love the 3d printed number plate. I was thinking of CNC for my Ulin Shay but after seeing how nice that turned out, I will follow your path.
I had not been thinking of wrapping the firebox but your work there is also inspirational.
Mike
Soot n' Cinders
Post by Soot n' Cinders »
Brian Hilgert wrote: Thu Apr 15, 2021 9:07 am Hi Tristan,
Let me know if you would like a file and/or link to the number plate for your shay. It was only around $100 with the gold plating, I think more like $70 if you go with a natural SS/Bronze infused color. (through Shapeways) Since I have the model finished, I can easly change the front number if you would like. Just let me know.
Thanks,
B
Thanks Brian! I’d be interested in the file, I don’t have a number or date in mind just yet but I’m going to need a number plate at some point.
-Tristan
Projects
Brian Hilgert
Post by Brian Hilgert »
Hello All,
It been a long time since I have updated this build post... too long. I continue to work on the Shay when time allows. The one feature that I really wanted to capture was the dome bases, the shay (at least the one I am modeling) had very large dome base castings. I decided to replicate these out of Aluminum. Before I hit the go button with a nice big chunk of expensive aluminum, I tested the program on a wood blank.
I'm glad I did because there was a glitch with the drip feed.
Once I fixed the Drip feed issue, I glued some wood in to fill the Oops and re-ran the program
I was happy on how the wood test piece came out so I mounted the 8" dia chunk of aluminum in, said a little prayer and hit the go button.
Many hours later, I was happy with the results.
Brian Hilgert
Same as with the Sand dome base
And in aluminum
I still have to do some light machining and machine the diameter so that they sit on the boiler.. but the hard part is done.
A little side Project that I had fun building was the cab out of foam board. I wanted to see how much access I had in the cab. When I was laying it out, I kept checking my math, This thing is bigger than I expected.
Brian Hilgert
Another update, The following pictures show the construction of the Bell. The documents that I have show that the 20 ton shay (the one that I am modeling) used a 50lb bell. I started with the harp, modeled it in cad, and created tool paths.
Once again, I used wood as a test before I ruin an expensive chunk of brass. The following shows the wood test piece being machined.
Once I was happy with the program, I pre-machined certain critical dimensions, mounted in the fixture, and hit the go button.
After the one side was machined, I flipped it over and hit the go button again.
I have to admit, It is not the prettiest harp, it does not have the flowing curves as other harps have. I have the actual Lima drawing for the bell and harp and I decided to go the prototypical route instead of using another design.
More to come on the bell and other goodies.
Berkman
Post by Berkman »
very cool!
Just curious, what type of CNC machine do you have? does it take a while to program it?
Brian Hilgert
My CNC is an old, worn out,Tree Journeyman 325, but it does what I need it to do. I can program it in conversational mode (Like G-code), but most of the time, I design the part in Inventor and create the toolpaths in Fusion 360. The hardest part for me was the handshake and drip feed from the computer to the CNC, it took awhile for "me" to figure it out. As for if it takes me long to program…Not really, but I am constantly playing with the program to try and get the best results.
B
Brian Hilgert
The following shows how I machined the bell. Once again, I used the old cnc mill. The bell is perfect for a cnc lathe but you use what you got.
First, I machined the inside
Flip it around and hit the go button
Once All the Machining was completed, I mounted the Bell in the lathe for finishing and polishing
Next is the bell lever
Assembled
Brian Hilgert
Ringer, Top Nut, and finished bell
I used a homemade radius cutting tool to machine the ball
Post by NP317 »
Beautiful!
Brian Hilgert
Some other goodies
The Boiler plate that my dad photoetched.
Build Plate that goes on the smoke box. I had this 3D printed in Stainless Steel. It was designed with the curvature to match the smokebox because you can not bend the printed SS piece. Unfortunately, due to the curvature, the final printed piece had steps in it. I did my best to reduce the look of the steps with a Dremel.... but darn, that printed SS is hard. I'm hoping that once I put some black paint on it, you wouldn't notice the steps as bad.
Tri-cock funnel - I just turned this on the lathe, drilled out the inside and ran the endmill down the center, The top is a separate piece that I soldered on.
Hand rail sanctions
Bell Harp stand off. The bell harp mounts to this piece and this piece mounts to the boiler. The Steam pipe for the turret and throttle rod goes though this.
rmac
Post by rmac »
Really nice work. All of it.
