Glenn. The drivers on the shay are 6.125in in diameterGlenn Brooks wrote: ↑Mon Aug 31, 2020 12:01 am Tristan, Iam researching a different gauge track and wheel set for drives and rolling stock.
Curious what size diameter drives you are using for your 2.5” scale Shay?
Building the 2.5" Scale Shay
-Tristan
Projects
Projects
Thanks much, Tristan!
Been a while since I've updated this... Not much happening on the shay, been busy with a new job. The latest was expanding the tank on the American Models lubricator, added 1in to one side which increased the capacity by almost 50% so I don't have to worry about running the tank dry as much anymore. The stock size was just barely enough to cover 2 2mi round trips on my home track, so I would run the pumps dry if I did any switching or slipped on wet rail.
-Tristan
Projects
Projects
I have a mechanical lubricator for the Shay I am building, which is intended for cylinder lubrication. But recently, having completed making the connecting rods, reliable lubrication of the big-ends concerns me. Any scale size oilers on the con-rods won't have much capacity. I'm also concerned about lubrication of the crankshaft main bearings as well. I have contemplated using the mechanical lubricator for the crankshaft bearings and installing a displacement lubricator for the cylinder.
What are others doing?
Bill.
Bill.
I use moly grease on the connecting rods, both wrists pins and big rod ends. It seems to hang around much better than oil and I have not noticed any wear in the bearings.Bill Hanks wrote: ↑Sun Jun 12, 2022 2:22 am I have a mechanical lubricator for the Shay I am building, which is intended for cylinder lubrication. But recently, having completed making the connecting rods, reliable lubrication of the big-ends concerns me. Any scale size oilers on the con-rods won't have much capacity. I'm also concerned about lubrication of the crankshaft main bearings as well. I have contemplated using the mechanical lubricator for the crankshaft bearings and installing a displacement lubricator for the cylinder.
Bill.
As for the carrier bearings, I machined extra large oil wells on top of the upper half of the bearings. They are fed by miniature drip oilers, though they over feed so are mostly for show..
-Tristan
Projects
Projects
G'day Tristan, sorry for taking so long to reply. I have contemplated grease lubrication of the connecting rods. Confirmation that you are using grease, has been good. What you have done with the carrier bearings is precisely what I plan to do. At my current rate of progress my Shay should be running on air by Christmas, this year. Thank again.
