Took my Logan 820 out of its crate and started putting it together and there were no belts. No motor nor pulley (?) Belts. Does anyone know what size or type belts I should buy?
Thanks in advance for your help.
Belts for Logan 820
Re: Belts for Logan 820
The type (and width) of the belt would be determined by the pulley on the spindle, assuming the spindle is driven directly from the motor, and not from a countershaft. In any case, the belt must match in order for it to drive properly, what ever it may be (flat belt, V belt, cog belt, as examples). As for length, that would depend on the motor mount and driver pulley you'd choose to use. If the spindle has a stepped pulley, you'd want to match the motor pulley so the belt length would be correct for all speeds. If the motor base is typically supplied with the lathe and mounts directly to the lathe, the belt length would be predetermined by the mount, assuming your pulley choice is correct. You really need to provide more information unless someone is familiar with the Logan 820 and they are all powered identically. They may not be. Dunno.
Motor. It is a wise decision to provide the suggested power, not larger. If you oversize the motor and have a crash, you may do more damage than you might have with the proper power. A smaller motor can result in broken tools when you stall the spindle due to insufficient torque, or severely limit depths of cut and feeds when roughing.
Sorry, I'm really not much help.
You should find what you need here. https://store.lathe.com/drive.html
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
3/4" Hunslet 4-6-0
Thank you all for your help.
Davis
Davis
I an now using synthetic lace up flat belts in my 10" SB.
Quite happy with them.
