Sheet steel tender tank sealant
With the horrendous cost of brass it's time for me to start considering building a tender out of steel sheet, possibly galvanized. I have worked a lot with stainless but it's hardly an economical alternative.
I've read through the archives and there doesn't appear to be a consensus on sealants. Any successes out there on a coat-and-forget modern sealant?
Please don't mention Phil Swift and Flex Seal, I've tried it around the house, it doesn't work well for anything.
Thanks much,
Denny
Thanks much,
Denny
"Measure twice, curse once."
- SPSteam2491
Re: Sheet steel tender tank sealant
I have used gas tank sealant (from KBS) in the past on a tender and it's starting to peel after 10 years of use. It took a solid 8 hours of preparing the metal and applying the sealant and will likely take 4+ hours to remove the sealant. I wouldn't do that again if I was starting a tender from scratch.
I'm building a new tender now in which the exterior shell will be sheet metal with rivet details, edge rounding, etc. The inside will be a separate welded aluminum water tank. This skips the need to find a robust waterproof coating that holds long term coverage for submerged water coated metals and allows common paint methods to be used for the exterior of the tender.
John LaFavor
Pacific Design Shops
John LaFavor
There is a gas tank sealer called Red-Kote that I and some of my friends have used and it seems to work extremely well.
I built the tank on my shay out of galvanized and I sealed it with good old fashioned plumbing soldered. It cant flake off or let water get behind it, and with good flux it will wick into the joint and help structurally as well. I did have to clean and redo a few spots after burning the flux but it was a fairly easy job.milwiron wrote: ↑Mon Feb 20, 2023 3:13 pm With the horrendous cost of brass it's time for me to start considering building a tender out of steel sheet, possibly galvanized. I have worked a lot with stainless but it's hardly an economical alternative.
Thanks much,
Denny
If I had to do it again I would use that method again without hesitation.
-Tristan
Projects
Projects
The big question is: how long do you want the tank to last? Almost every coating is water soluble to some degree. The sealers that last the least are ones that are designed to occasionally repel water from external surfaces. So look for a coating (or actual seam sealer) that is made for 100% submersion. Once you protect the surface of the tank, with an impervious primer and topcoat for longevity,all you need do is make sure any and all seams and inspection plates are water tight. I personally prefer marine seam sealers, such as Dolphinite to seal inspection plates and lap joints that are are bolted or riveted.
- Greg_Lewis
I think Jack Bodenmann has said that he makes an inner tank out of PVC or some similar plastic. The advantage of that is that you can do whatever you want with the outer tank for aesthetics and not worry. The plastic is easy to work with and will last forever.
- Dick_Morris
I have the front of a stainless steel fridge that I saved when the fridge failed. I think it will be adequate for tender sides and possibly the top and bottom if I use some care with internal supports/baffles. Dishwasher fronts are another source of SS sheet.I have worked a lot with stainless but it's hardly an economical alternative.
Last year I thought I would save some time by using marine sealant on my (brass) tender body. I followed the directions with regards to cleaning the surfaces and waiting the appropriate amount of time for it to dry before putting in any water. It leaked like a sieve and I spent the next couple of weeks with an assortment of scrapers, wire brushes and flat head screwdrivers removing the nasty stuff from the tank!!
After I finished scraping ALL of the gunk off I then soft soldered the whole thing and now its perfectly water tight. Next time I will go right to soldering and save a lot of time and frustration.
P.S. I cant remember which marine sealant that I used but it was available at the big box stores, in my case Home Depot.
-Frank K.
Devcon flexane.
Clean and prime and paint it in.
Prep with fine carbide blasting #80 grit) and prime with the two recommend primers
you cannot tear it off the brass...gotta cut it off with a razor blade....or blast it off with the grit.
Lifetime solution...don't care how long you live.
I have a brass tender I did 40 years ago that is still tight. A steel tender done 20 years ago.
Because it is two parts you do not have to worry about drying...you can also paint more on if you have a leak.
Ain't cheap, but you get what you pay for.
- Attachments
- 20220726_172922.jpg (96.72 KiB) Viewed 2337 times
One of the most important things to making a tender last, in my opinion, is having a way to be able to completely drain all the water out of it. I have started putting a low spot right in the middle of my tender tank floors. Sometimes two spots if it is a bigger tender. I basically took a 6" piece of pipe, set the tank on it, and then used a rubber mallet to beat the floor down inside of it so that it was about 1/4" lower in the middle than the surrounding floor. I made sure my small depression would fit in between the tender frame rails. I then silver soldered a 1/4" fitting I made into the bottom of that depression, and drilled it through into the tank. Now, a simple valve or petcock will drain the tender tank very well. I then leave it open and try to get as much out as I can while I'm prepping to load. A lot of people drain their tenders through the valves that go to the locomotive, and most of those will leave about 3 /16" to 1/4" of water standing on the floor of the tank. Like a boiler, just getting it dried out after use will extend its life tremendously, so put some thought into how to easily and completely drain it.
I have always built my tenders from brass, regardless of the cost....after fitting, riveting and soldering....you will have a lifetime tender...with no need for glues and goos, that eventually leak, and are in constant need of repairs
Some years ago, when looking to find the latest & greatest sealant for a tender tank, a chum suggested I look into what the auto and motorcycle restorers were using to seal their gas tanks. He figured they would always know what the latest & greatest was.
GWRdriver
Nashville TN
Nashville TN
