Best cutoff tool profile?
Re: Best cutoff tool profile?
I found square head set screws for about $1.00 each at McMaster
--earlgo
- Greg_Lewis
As they say, great minds think alike!
So do crazy ones!
Greg_Lewis wrote: ↑Mon Dec 05, 2022 9:44 pm Here's an interesting holder. I always thought a cutoff blade should be fed in straight, no rake, but this clearly shows it at an angle with some back rake. What do you think about that?
yes Greg, that is the proper way, and the original Aloris method for parting tools .
Some of the Aloris imitators made them straight to save costs
Rich
https://allindustrial.com/aloris-ca-7-u ... 2668391b73
- Greg_Lewis
Rich_Carlstedt wrote: ↑Wed Dec 07, 2022 12:51 pm yes Greg, that is the proper way, and the original Aloris method for parting tools .
Rich
Thanks, Rich. That's interesting as I see lots of illustrations and holders other than the Aloris type that run the tool in straight, zero rake.
nice thing about holders with rake....very easy to 'level the tool off' in a grinder if you want zero rake'.
this is something that I do with some materials....
My best cut off blade is one made with high grade HSS German steel. All the cheap Imports and off brand (HSS) blades I’ve used are basically poor to worthless. So have become a believer that the grade of steel is more important than the profile…
Just a note. Steels alloys are defined by standards, typically SAE, ISO or UNS. Regardless of where they are made if they meet this specification then they are they same everywhere. Referring to steel by country is a marketing gimmick that should be eliminated.Glenn Brooks wrote:My best cut off blade is one made with high grade HSS German steel. All the cheap Imports and off brand (HSS) blades I’ve used are basically poor to worthless. So have become a believer that the grade of steel is more important than the profile…
An M35 HSS tool coming out of China will always have a higher hardness than an M2 tool out of Germany.
Note that I am assuming here that the manufacturer is honest and what they say the steel is is in fact what it is. Unscrupulous behaviors is another kettle of fish here and sure it can be more prevalent in some portions of the world than others.
Sent from my SM-S908E using Tapatalk
- tornitore45
Obviously, you have not dealt with Chinese manufacturer. I worked for a major computer company and rejecting non-compliant parts was a full job.Note that I am assuming here that the manufacturer is honest
I am not talking about the rare defective part; I am talking about cheating by a process that could not possibly meat the specs.
- tornitore45
Where did you buy it?My best cut off blade is one made with high grade HSS German steel.
