steamingdon wrote: ↑Sun Mar 05, 2023 11:07 am
That BIG nut is going to fit in cylinder without striking the head cover?
The head cover is bored as Bill said. Works great. I’m such a newbie that following the 1949 plans is all I know to do. I figure if deviation is required I’ll prove it and then compensate. In this case it worked as drawn.
New to live steam
Building 3/4” 4-8-4 Northern &
1” 4-6-2 Pacific
I'm still on it! Work has been crazy busy but I found time this week to make some progress. These reversing arms turned out nice in my opinion. I just have to decide if I am going to silver solder them or braze them like the plans depict. I haven't brazed anything before. I wish I had a jewelers torch and supplies since the joint to be soldered is so small. O well, I'll figure it out.
New to live steam
1” 4-6-2 Pacific
If you happen to have a small heat treat oven, you might consider silver soldering that way. Apply the required flux, then add solder to the joints. Place them in the oven and heat until the solder has flowed. The uniform heating yields excellent uniform solder joints without overheating the solder.
The solder must be fashioned so it can't move away from the desired joint while being heated.
I silver solder small stuff by placing it atop a piece of 1-inch angle iron in the bench vise. Then I heat from below, through the angle iron, with my o/a torch set with a long feather on the flame. The heat soaks through the metal and the solder melts into the joints. Use the black flux.
More progress! Silver soldering turned out nice. I bead blasted levers and then polished on brass wheel. Does tumbling work for polishing up in the nooks and crannies?
Lane
New to live steam
1” 4-6-2 Pacific
One thing that can help by tumbling is the use of stainless as a media. It's made quite small in diameter and with sharp edges that can reach in pockets. It is commonly used for burnishing.
I had the opportunity to put my recently purchased and rebuilt rotary table to good use. These eccentric rods had been challenging my brain over the last few months. I have never machined anything so complex. I had never used the rotary table to its full potential and I had never used a slitting saw. Needless to say I learned a lot! It took twenty hours spread over four days to produce these two rods. The first attempt got scrapped due to drilling the wrong size holes! The second attempt went much better and I used some good planning to conserve tool swap outs.
Eccentric Rods.jpg (81.29 KiB) Viewed 1483 times
The finished product turned out great and fits!
New to live steam
1” 4-6-2 Pacific
"...art.' Well said.
When people ask me what I do in retirement, I say I fabricate kinetic sculptures.
And then show them pics of my 2 steam locomotives.
