Driver wheels profile
Moderators: cbrew, Harold_V
Emfinger
Post by Emfinger »
I have a IBLS wheel gauge, but I'm not sure how to use it. Is there a how to sheet somewhere?
Thank you
Tom
Bruce_Mowbray
Re: Driver wheels profile
Post by Bruce_Mowbray »
The first photo is shown in the proper position. The back (side with the tounge) of the gauge is held parallel with the back of the wheel.
Bruce Mowbray
Springville & Southern RR
Post by Bill Shields »
Too bad more people do not use them...
Emfinger
Post by Emfinger »
OK, thank you. Now is this wheel OK or needs work?
Work
Fender
Post by Fender »
This wheel does not exhibit the typical wear pattern. Usually, the flange wears so that it is narrower/thinner than when it was new. These flanges look wider/thicker than the gauge you are testing it against. Looks to me that the wheel was made that way. Is this 7.25” or 7.50” track gauge? Also, the tread is exceptionally wide. Is this a narrow gauge (2.5” scale) loco?
Dan Watson
Chattanooga, TN
Post by NP317 »
Were those two pictures of the same wheel?
Emfinger
Post by Emfinger »
Not the same wheel.
The scale is 1.6"
OddDuck
Post by OddDuck »
Where would one get one of said gauges?
"If you took the bones out they wouldn't be crunchy!" -Monty Python's Flying Circus
BAdams
Post by BAdams »
Profile for 1.5 and 1.6 should matter not.
I personally like wide tires.. esp on center drivers. Helps keep from falling through on tangents.
Bill Shields wrote: Sun Sep 25, 2022 1:06 pm Profile for 1.5 and 1.6 should matter not.
Are you sure?
I recall being at the Northwest Live Steamers Track (Molalla, Oregon) many years ago when a builder unknown to me showed up with a steamer. The profile of his wheels was such that he couldn't operate on their track. If memory serves, his flanges were wide and square.
