No ..by the time I could afford one BMW cycles went from 45HP to twice that, making the VW engine irrelevant.
Do a Google of bmw cycle with VW engine. You will see several.
Road trips are always an adventure.....
Re: Road trips are always an adventure.....
- liveaboard
I was stuck in traffic on a highway above Boston in my old Ford truck, and the strangest motorbike I ever saw was standing next to me; so I rolled down the window and shouted out; "What is it?"
"BMW with a Subaru engine!" he answered.
Long ago I read a story in Cycle magazine about a bike called Amazona made in Brazil around a VW engine.
Anyone ever seen one?
Today they call them gold wings.
Imitation is the sincerest form of flattery.
Never seen an Amazonia in the flesh, but the concept is the same as previously discussed.
I'm always amazed when people tell me this. I couldn't even get the bolts to the halfshafts of my baywindow bus out in that time, but I know I'm slow.Greg_Lewis wrote: ↑Wed Jun 29, 2022 9:04 pm (You can pull the engine in 20 minutes with a screwdriver, one wrench, and a floor jack.)
John Brock
- liveaboard
My dad reported that his German mechanics could swap a VW motor in 45 minutes.
They would time it for fun.
That's real time for guys who specialized in it, and when the cars were fairly new.
- Greg_Lewis
Yup. And that's working alone. The 45 minutes includes time for a beer .
As I remember, there were only 4 bolts holding the engine to the transaxle. Two clamps for the cables to the heater boxes, the throttle cable, the gas line, and the wiring to the distributor and alternator (Or was it a generator? I think my '63 may have been 6 volt — not sure). You also have to pull the sheet metal pans that seal off the engine compartment from the road below. You jack the car up as high as you can get it (this is for the curbside engine swap), slip the jackstands under the axles, and then use the floor jack under the center of the case to drop it down. Then you can just pull it back and out from under while it sits on the jack pad.
The install takes a minute longer because you have to line up the splined shaft from the crank to the clutch (Now I've forgotten. Is the clutch on the engine or on the transaxle?)
Clutch on flywheel. Splined drive in clutch center drives the transaxle shaft.
I have changed one by myself in under 2 hours, but had all the tools and the support device (based on a 55 gal oil drum) handy...and was working on a air over hydraulic lift.
Generator in those years, even when 12 volts
