1/6th scale steam launch
Steamer Al
Post by Steamer Al »
Well here we are two years in to a R/C steam launch project. As always these things get carried away and more complicated, part in fact due to motivation from some of the incredible workmanship I see posted on this board.
Boiler is over scale, but will be mostly hidden inside a cabin with just the backhead visible. Engine is one I designed, 5/8" bore and stroke simple twin. Its a balance between ease of manufacture with locally available hardware and metal from my scap bin versus something that looks reasonably scale. Lots of the brass will be covered or painted to help with that. Currently finishing the crossheads then on to piston rods.
Lots to do, even once the engine is done hopefully by the end of the year. Feedwater pump, feedwater heater, a very simple keel condensor, water tank, not to mention the finish wood work. I dream of steaming it around the beach next summer but realistically it will be a couple years away yet.
Enjoy!
Alex
Re: 1/6th scale steam launch
Post by NP317 »
Alex:
Very nice looking work. And steam launches (of all sizes) are close to my heart.
https://www.northweststeamsociety.org/_ ... 1f8e72.pdf
The Pacific NW/Salish Sea remains a hotbed of such activity.
Please keep sharing your progress.
Steamer Al
NP317 wrote: Tue Jun 07, 2022 10:50 am Alex:
Thanks Russ! I sure like your launch. I'm curious what you do for cylinder lubrication? A bit more complicated with a condensing setup I imagine.
Cheers
Alex
Post by NP317 »
Alex:
My steam launch has an original Blackstaff-Woods steeple compound engine that only requires internal condensate for lubrication!
No oils involved which greatly simplifies condensate return and boiler water feed. Saturated steam at about 125 psi is required, so no superheating involved.
It continues to run well after more than 50 years. A credit to the designers.
Steamer Al
Thanks Russ! I was considering trying the same, but with a brass bore and bronze pistons I suspect it wouldn't wear as well as all cast iron.
Alex
