Milling machine with a BT or ISO spindle
rmac
Re: Milling machine with a BT or ISO spindle
Post by rmac »
xzsawq21 wrote: Perfect solution for my application.
Except how are you going to manage the odd angled cuts? Unless the two sides of the V are actually at 90 degrees to each other, I don't see how you'd do this on a manual mill.
xzsawq21 wrote: What do you think about Optimum MH 22V? I don't know the quality of the Optimum milling machines
I don't know anything about these machines, either but one of the more respected YouTube guys, Stefan Gotteswinter, has at least two videos where he talks about his Optimum MB4. Not the same machine as you mentioned, but maybe one or both of those videos will help you:
https://www.youtube.com/watch?v=vFtQrWbbeI0
https://www.youtube.com/watch?v=OSjLhEWY1Vg
He also has a web page with links to more info about his machine.
https://gtwr.de/optimum-mb4-milling-machine/
Again, this is a different model than the one you mentioned, and I don't personally know anything about it.
-- Russell Mac
Post by Bill Shields »
I have to assume that you are looking for a CNC machine to make these parts?
RSG
Post by RSG »
rmac wrote: Thu Mar 03, 2022 6:33 pm Except how are you going to manage the odd angled cuts? Unless the two sides of the V are actually at 90 degrees to each other, I don't see how you'd do this on a manual mill.
-- Russell Mac
The only easy way is to do it with a rotary table, which I'm going to assume he'll be buying along with the mill....or shortly after :roll:
Or some creative fixturing...
