Minimum radius for 2 ft. gauge
Forum rules
Using a set of driving wheels that are 20" in diameter and 34" center to center on the axles.
Re: Minimum radius for 2 ft. gauge
A bit more info needed before providing meaningful response:
How many driving axles?
How many leading or trailing axles?
Side play in driving axles?
Side travel or play on leading or trailing axles?
Any blind driving axles?
Here is an informative and similar thread.
http://www.chaski.org/homemachinist/vie ... hp?t=94864
It’s a quick read as only 5 or 6 replies. The essence is, the trailing truck can disproportionately increase minimum turning radius.
Also, a quick rule of thumb mentioned is: wheelbase (W) times 20 = minimum turning radius (R)
So in your case - 34” x20 = 680”
Or, R= 56.7’.
A respectable minimum turning radius considering 20” drivers, which implies a fairly large locomotive- in the 4” (1/3 rd) scale class.
BTW, I recently acquired Ben Hammer’s complete pattern set for casting parts for his 4” scale 4-4-0 American. The drivers are 20” diameter spoked wheels. Could also be used for an Atlantic 4-4-2 in similar scale and gauge.
Or, R= 56.7’.
Some factors to take into account:
25+ Years of SolidWorks experience...now I feel old.
"You can lead a horse to water, but you can't make him drink."
"Winning an argument on the internet is like winning the Special Olympics."
www.facebook.com/HillcrestShops
http://www.catskillarchive.com/rrextra/plate097.Html
This is the model we are working on. It is scaled for 2 ft. gauge.
Hello Friends
A Forney type of locomotive will require a larger turning radius than even a short wheelbase 0-6-0 this is due to its greater distance from the front driver to the truck pivot . That distance will determine the minimum radius . You could make the same locomotive with a short 4 wheel tender and get close to the same appearance. If you really want a Forney type may I suggest looking into some of the Mason Locomotive works engines.. they were articulated and would go around sharper curves.. if I recall correctly I think porter advertised their 0-4-0 locomotives going around 25 foot radius curves.you have a nice project ahead of you happy building..
As K. Brouwers notes the limiting factor for the minium radius on a Forney is the swing of the Trailing Truck.Springhill-RR wrote: ↑Mon Aug 30, 2021 10:19 am http://www.catskillarchive.com/rrextra/plate097.Html
Mr. Jack Bodenmann found a solution to alleviate this problem by getting rid of the traditional swing bolster and instead using roller bearing ( https://www.mcmaster.com/track-rollers/ ) to make a bolster that would roll side-to-side in a channel. This allowed his 3-3/4" scale 7-1/2" gage 2-4-4T #9 to negotiate much tighter radii than it would have normally been able to.
Figure out how much travel you'll be able to get on your Trailing Truck and that will tell you the minimum radius of track.
I plan to make the tender separate.
James, where is that locomotive, British looking machine with an American style box car in the background pretty odd I would say. If it weren't for the background it looks a lot like the little railroad at the London Steam museum at Kew Bridge.
Freight container is Evergreen Taiwan...which means nothing..they are everywhere
Statfold barn rwy in the UK.
- Erskine Tramway
My 1919ish Koppel '100% American Owned, General Catalog Number One' shows 30-foot radius on their 2-foot gauge portable track. They also had 12-foot radius switches.
So, that would probably indicate what was 'standard' at the time. Admittedly, the equipment, cars and locomotives, was probably all 4-wheeled.
Mike
Mike
