quill wheel
liveaboard
quill wheel
Post by liveaboard »
My mill came with a 14mm L wrench instead of a quill wheel.
So of course, I made one.
I measured the drop with 1 rotation and found it to be 65mm. So I made a wheel with 65 little cuts in it, and stamped numbers in.
That's not easy; it took me 3 tries and it still has one bad.
I bored it through and across to fit a 4mm ball as a lock. That gets pushed out by a center rod with a screw knob.
The paint is horrible and I think I'll probably sand it off and do it again.
I think I need to shorten the spokes a little too, but I'll wait and see how it is in practice first.
I hardened the center rod.
kl7sg
Re: quill wheel
Post by kl7sg »
Nice Job!!!
Have a nice day,
Mike
liveaboard
Re: quill wheel
Thanks.
