John's Clishay build log
Re: John's Clishay build log
Test to 200 PSI for 10 minutes
- Attachments
- 200PSI.JPG (205.67 KiB) Viewed 2716 times
This sealant works better than anything ese II have tried.
- Attachments
- Joint sealant.JPG (133.29 KiB) Viewed 2716 times
Water tank from front of Clishay
- Attachments
- Tank.jpg (74.99 KiB) Viewed 2714 times
I did the test three times rolling tubes into fixture. I did an "easy" force roll, and I had annealed each tube with propane torch. I didn't need to re-roll any tubes. I tested each time at 200 PSI for at least 10 minutes.
I wanted to test my rolling ability before rolling tubes in boiler, which are at best difficult to remove.
To clarify, sealant is only on pump fittings, not tubes. Tubes were inserted dry.
- Attachments
- Rolling Tubes.jpg (1.06 MiB) Viewed 2497 times
Fire Box Door
- Attachments
- Fire Box Door.JPG (394.7 KiB) Viewed 2445 times
Have you made provisions for opening the door "a bit" and holding it in that position?
Useful for reducing steam loss through the valves while running (often downhill) without fooling with the fire.
Yes ..even with propane fired locos.
didn't know about that - what do yo mean a bit, like a 1/2" ?
Door swings free
- Attachments
- IMG_2220.JPG (327.9 KiB) Viewed 2352 times
1/4" or 1/2" gap or similar.
Ever seen it on a full scale loco fire door?
