Manson Hot Air Engine Build
Re: Manson Hot Air Engine Build
rmac wrote: Wed Nov 24, 2021 1:58 pm I'll try to post a video of it running if I can figure how to do that.
Videos can't be posted on the board, but they can be linked if posted elsewhere. Youtube, as an example.
Beautiful piece of work, Russ.
Edit: I took a look at the link provided for stainless wick. Looks like it's just stainless aircraft cable.
rmac
Post by rmac »
rmac wrote: Might be worth experimenting by just twisting together a bunch of wire to approximate the Kontax wick.
Well, well. That worked too good. Way too good! I unraveled six or seven pieces of #12 stranded copper wire and then twisted them back into a 1/4" diameter cable that would fit into the alcohol burner. For whatever reason, the alcohol wicked up the wire, spilled over onto the top of the burner lid and then onto the wood base. Before I knew it, I had one heck of a fire going. I need to play around with the whole thing some more in a setting where I'm not so likely to set the house on fire.
Harold wrote: Videos can't be posted on the board, but they can be linked if posted elsewhere. Youtube, as an example.
Yes, I've seen that mentioned here before. My problem is that I've never before gone through the exercise of taking a video, getting it from the phone (or whatever) to a computer, editing it, and then uploading it to the internet. Guess it's time to learn all that so I don't wind up being the last guy on the planet who doesn't have a YouTube channel.
Harold wrote: Beautiful piece of work, Russ.
Thank you.
-- Russell Mac
rmac
Post by rmac »
rmac wrote: For whatever reason, the alcohol wicked up the wire ...
Well, not quite. As it turns out, the alcohol wasn't "wicking up the wire", it was being pushed up through the wire by pressure building inside the burner as everything heated up. I put a little vent hole in the lid and that solved the problem. The wire wick seems to work really well so far. The burner makes an almost invisible blue flame with no smoke and plenty of heat to run the engine. And of course the wire itself doesn't burn at all. All good.
-- Russell Mac
pete
Post by pete »
Felt might work?
pete wrote: Wed Nov 24, 2021 10:21 pmFelt might work?
Assuming it's wool felt, yeah, it would work, although wool doesn't burn well. It would present some of the same problems that cotton does, so there's likely little benefit in trying. I am VERY familiar with wool and how it burns, thanks to having processed wool carpets to extract precious metal values.
Felt is also made from synthetic materials, most of which burn like gasoline when heated. Learned that from processing carpets, too.
pete
Post by pete »
Yep I should have been more specific, I did mean wool felt and not the synthetic variety.
rmac
Re: Manson Hot Air Engine Build - We Have Video!
Post by rmac »
To kind of close the loop on this, I made a video of the engine running and got a buddy to post it to his YouTube channel. Here's the link:
https://youtu.be/95z_860ozsQ
In case anybody is interested, I also made a care package that includes the Fusion 360 file, 2D drawings of all the parts, some photos of individual parts, and some miscellaneous notes. Look for it here:
http://www.ibab.org/tsdblog/manson_iii_plans.zip
Thanks to everyone for all the interest and help!
-- Russell Mac
Post by NP317 »
Successful!
RSG
Post by RSG »
Very cool Rmac 8)
pete
Post by pete »
Very cool & shiny, but your on a slippery slope Russell. Most who get into these engines seem to slowly end up making them more and more complex with more and more exotic and expensive materials. Then there's just how slow they can be made to run, that's a nice set of design and engineering problems right there. Afaik NASA did a huge amount of experimentation with this engine type. I haven't checked, but I'd be surprised if there findings weren't accessible by the general public with a bit of digging.
rmac
Post by rmac »
RSG wrote: Very cool ...
pete wrote: ... and shiny
Thanks, guys. pete, you're right about the slippery slope. In my brief career making these things I seem to discover potential improvements about 3/4 of the way through the construction process, after it's too late to actually incorporate them. Right now I have the piston/cylinder assembly left over from attempt #2, and it only makes sense do something with it, perhaps with a bigger flywheel.
And then the current model has a vibration that I think is just due to the piston assembly moving back and forth. So how about a horizontally opposed, two cylinder version arranged so the pistons move in opposite directions?
And then it would be interesting to play with counterweights and such to perfectly balance the flywheel/connecting rod system.
And then ...
-- Russell Mac
Post by GlennW »
rmac wrote: Sat Dec 11, 2021 6:44 am Thanks, guys. pete, you're right about the slippery slope. In my brief career making these things I seem to discover potential improvements about 3/4 of the way through the construction process, after it's too late to actually incorporate them.
Experience is something you get right after you really needed it!
