Fixing the electrics in my old German mill Ruhla 250/710
Re: Fixing the electrics in my old German mill Ruhla 250/710
Well that is good.
Your relays will be fine. A transient protector in parallel with each coil could lengthen contact life.
- tornitore45
...lengthen contact life of the driving relay.Your relays will be fine. A transient protector in parallel with each coil could lengthen contact life.
AC snubber you can start with R=1/2 x Rcoil and C = 0.47uF or less X Rated Capacitors are NOT rated as Movies
Values have wide latitude when one has not much data on coil
- liveaboard
All I understand from that is capacitors.tornitore45 wrote: ↑Thu May 27, 2021 12:31 pm
I intend to add reversed diodes to the clutch + brake coils to drain reverse emf when disconnecting.
We know that when this machine was built, silicone diodes weren't available...
Measure the resistance of one of the relay coils. That's Rcoil. Connect a resistor equal to Rcoil/2 in series with a .47 uF capacitor. Connect that series combination in parallel with the relay coil. Do that for each relay. Use 1/4 watt resistors and 100 volt or higher ceramic capacitors.
Or connect a 50 volt transient protector (MOV or TVS) across each coil.
- liveaboard
got it, thanks for the clarification.
But with 230v coil voltage, don't I need capacitors rated at 230+ ?
Unless you like fireworks...yes on higher voltage
- liveaboard
I love fireworks.
Maybe not in the workshop though.
- tornitore45
The diode is good for any coil that is DC driven.
For coils AC driven a MOV rated Higher than the line voltage or a RC snubber as John described. R + C in series rated for line voltage.
TVS are like 2 Zener diodes back to back they are a Semiconductor "equivalent" of the MOV
I somehow got the impression that you had a 24 V control transformer. Yes, the snubber network components must be rated for the coil voltage plus a comfortable margin.liveaboard wrote: ↑Fri May 28, 2021 2:10 am got it, thanks for the clarification.
- liveaboard
230v control transformer; input voltage is 380.
Some other models by this company did use 24V control.
- liveaboard
I'll connect the power tomorrow.
I'm only slightly terrified.
