Gear cutting
KellyJones
Gear cutting
Post by KellyJones »
Successfully cut a gear on my milling machine. Very complex task, even with a form cutter.
Finished gear
Finished gear
cutting the gear
cutting the gear
basic set up
basic set up
blank ready for cutting
Kelly Jones, PE
George Bernard Shaw
(1856-1950)
Re: Gear cuting
Well done, Kelly. Looks great!
Re: Gear cuting
Post by GlennW »
Very well done!
Re: Gear cuting
Post by SteveM »
Nice.
It's a tedious, nerve wracking job from what I have seen on youtube videos.
I have to make some for my dividing head (ironically using my dividing head).
whateg0
Re: Gear cuting
Post by whateg0 »
It is tedious, and even folks that we all admire can screw it up once in awhile. I recently watched a video of Stefan Gottswinter screwing up a gear because he didn't lock the quill. I have some worm gears to cut in the near future. I'll cut them in aluminum first, before scrapping a bunch of expensive bronze.
Dave
tornitore45
Re: Gear cuting
Post by tornitore45 »
Good luck, that is no guarantee.
I once cut 4 camshaft
1st try mirror image of a good part
2nd try a double width lobe was cot short
3rd try I got everything down path, I was really jamming and overshoot the flank, made it almost round
This is ridiculous, better sleep over and try the next day
4th try I got a camshaft I could use
whateg0
Re: Gear cuting
Post by whateg0 »
tornitore45 wrote: Fri May 01, 2020 2:37 pm
So, you're saying I should cut it in aluminum first, second, and third? :P
Dave
Re: Gear cuting
Post by SteveM »
whateg0 wrote: Fri May 01, 2020 7:31 pm So, you're saying I should cut it in aluminum first, second, and third? :P
No, he's saying you cut all of them out of aluminum except the last one.
armscor 1
Re: Gear cuting
Post by armscor 1 »
Cutting a 150 tooth mod1, you have to stay focused mind starts to drift off and that is where you forget the turns, forget to advance the sector arm or lock the spindle.
Total concentration and no interupptions
RMinMN
Re: Gear cuting
Post by RMinMN »
Would this be the good place to fit in a stepper motor to make the required amount of turns. They can be quite accurate and repeat very nicely without getting distracted. The gcode for something like that should be quite simple.
tornitore45
Re: Gear cuting
I did cut the 60 teeth gear perfectly and the 1.5 turns on the RT handle was chiseled in my mind.
When it came the time to cut the 30 teeth started out advancing 1.5 turns, after 4 or 5 teeth they look kind of small and crowded.
whateg0
Re: Gear cuting
Post by whateg0 »
RMinMN wrote: Sat May 02, 2020 7:51 am Would this be the good place to fit in a stepper motor to make the required amount of turns. They can be quite accurate and repeat very nicely without getting distracted. The gcode for something like that should be quite simple.
Added benefit of not needing to be an integer number of holes, too!
