silver solder alluminum
GaryD
Post by GaryD »
Is it possible to silver solder aluminum?, the project I wish to build can either be made of aluminum or brass, I would prefer aluminum cause its easier to cut..TIA GaryD
Re: silver solder alluminum
I am unaware of any silver soldering processes for aluminum, which is difficult to solder. It has the ability to oxidize rapidly, which contributes to the problem. Add to that the fact that silver solder often melts about the same time aluminum does. If memory serves, there is a zinc alloy that can be used with success.
Others may have a totally different view on this subject. I do not profess to understand it well.
ken572
Post by ken572 »
GaryD wrote:Is it possible to silver solder aluminum?, the project I wish to build can either be made of aluminum or brass, I would prefer aluminum cause its easier to cut..TIA GaryD
Gary,
Check This Product Out, From Muggy Weld.
Watch the Demo video on Aluminum.
http://www.muggyweld.com/
A cheaper version is also available at Harbor Freight.
http://www.harborfreight.com/catalogsea ... elding+rod
You have to practice on scrap to build your technique and skills.
Ken. :)
One must remember.
Ken.
GaryD
Post by GaryD »
I have decide to go ahead and make it with brass, when I get it cut and ready to put together I will show pictures..GaryD
magic9r
Post by magic9r »
I had to do this in my youth when I needed to repair a starter motor (Vauxhall HC Viva) with Aluminium stator coils, I found a local jeweler who was willing to help once he found out I was working on my car but can't recall the details, just that I was able to solder a copper conductor to the Aluminium stator,
- Nick
ken572
Post by ken572 »
magic9r wrote:I had to do this in my youth when I needed to repair a starter motor (Vauxhall HC Viva) with Aluminium stator coils, I found a local jeweler who was willing to help once he found out I was working on my car but can't recall the details, just that I was able to solder a copper conductor to the Aluminium stator,
- Nick
:D Nick
You might enjoy looking at these.
MuggyWeld
Aluminum Welding, Aluminum Brazing, Aluminum Soldering
http://muggyweld.com/aluminum-repair?gc ... fgodW1AA_Q
How to Solder Aluminum
http://www.wikihow.com/Solder-Aluminum
Durafix
http://durafix.com/
Malloy
http://www.malloy.it/eng/prod_alluminio_zinco.htm
Ken. :)
One must remember.
Ken.
