3 1/2" Gauge Switches
I am Looking for information on building some 3 1/2" switches for my railway. Mostly looking for dimensional information. I am finding a lot on 7 1/2" gauge switches but not so much on 3 1/2" gauge. I am currently using switches from Lawn Tracks. They are OK but do not look very realistic, my locomotives have the tendency to pick a switch from time to time when I am "Hauling the Mail". My track panels also came from Lawn Tracks, they are made of flat bar, 1/4" x 3/4" so that is what my new switches will be made of as far as the rails. I have the book " Build A 7 1/2" Gauge Railroad in Your Back Yard" by Laurence Johnson, and in it he goes into depth on how he constructs his switches, but they are in 7 1/2" gauge. His process will work just fine for me. My main line runs 25' radius curves, I do have some 20' radius curves also. The Lawn Track switches are 20' radius curves. My current locomotives do not have any problems with those, and I do not think the Pacific that I am currently constructing will have any problems as I have pulled it through those before. Any help or guidance would be much appreciated, Thanks, Zach
Re: 3 1/2" Gauge Switches
Maybe this will help. You need to know the frog number/ratio to layout the switch properly, but you should be able use these drawings as a guide.
https://www.wmata.com/business/procurem ... awings.pdf
7.5" Allen Mogul
The railroad is almost done.
G. Augustus
Monte Rio, Ca.
G. Augustus
Monte Rio, Ca.
While not prototypical to class 1 track, the stub switches you have should serve you well.
Actually stub switches are prototypical. The East Broad Top and the Wiscasset, Waterville and Farmington in Maine, still use them in certain applications.Bill Shields wrote: ↑Tue Jan 03, 2023 7:15 am While not prototypical to class 1 track, the stub switches you have should serve you well.
But no….not on Class 1 roads. Just as information…”Class 1 Track” is only good for ten miles per hour. Class 6 is good for 110 miles per hour.
Keith
