Lab-Volt mill conversion - (attn Marty)
Rex
Re: Lab-Volt mill conversion - (attn Marty)
Post by Rex »
One more thing: I have temporarily removed the CNC4PC C11 board from the circuit and subbed a $15 Chinese BOB. This board has almost no variables (charge pump, enable pin etc) to deal with. If I can get it running this way I may go back to the C11.
Rex
Post by Rex »
Still trying to sort out the power supply voltages. Here's what I am measuring:
Lab volt connections
Power supply
Transformer output 33.7 V Ac
30V DC at rect. Bridge
96V at cap
74VAC yellow
74VAC orange
Red/black drive power 7.5VDC
That last line does not make sense. I wish I knew what the steppers required.
Have a local guy helping me, two heads better than one hopefully. Stay tuned
Rex
Post by Rex »
Marty, do you have any idea what voltage these steppers require?
Gotta be more than 7.5 volts!
Marty_Escarcega
Site Admin
Post by Marty_Escarcega »
Rex wrote:Marty, do you have any idea what voltage these steppers require?
Something is not right....I need some more detailed pictures....
Jon.unique
Post by Jon.unique »
The stepper driver boards are powered by 42vdc
Jon.unique
I just lost my 42v...its only measures 1.4v
I still have the 12v though
I hsve no idea what happened......i just powered on today and no axis would move...found out no 42v to driver boards
Marty_Escarcega
Site Admin
Jon.unique wrote: Fri Aug 27, 2021 6:00 pm I just lost my 42v...its only measures 1.4v
Check for a blown fuse back track.
Marty
