Elesco feed water heater
little giant
Re: Elesco feed water heater
Post by little giant »
Mike- I will be putting the elesco feed water heater on a NYC Mikado H10b, and later I will make a post for building the H10b locomotive with tender.
Berkman- The feed water heater is design to come apart and I am using copper and brass. At end of season take apart and put it in a bucket of water and CLR and rinse off, dry thoroughly and put it together for next season.
Sandiapaul
Post by Sandiapaul »
Love to see the H10, one of my fav locos!
little giant
Finished the water passages in the fixed end of the water heater. I need to put in the inlet and outlet fittings after deburring all the sharp edges.
Berkman
Post by Berkman »
Very interesting! Can't wait to see more pics and the mikado build log.
kcameron
Post by kcameron »
I've never seen the guts of one or internal drawings. So I'm waiting and watching this to figure out how this all ends up going together and working.
-ken cameron
Syracuse Model Railroad Club http://www.SyracuseModelRr.org/
CNY Modelers http://www.cnymod.com/
Finger Lakes Live Steamers http://www.fingerlakeslivesteamers.org/
Member JMRI Developer Team http://www.jmri.org/
mailto: kcameron@twcny.rr.com
In the Upstate New York US area of the world
Berkman
Post by Berkman »
As I understand they were quite the birds nest of heat exchanger tubing with the exhaust steam surround them. Almost similar in concept to a watertube boiler.
little giant
Hey Ken here is a screenshot of the “guts” and how the water travels through the heater.
kcameron
Post by kcameron »
Now I'm getting the idea of what the machining has shown. Wow, that's a lot of tubes.
So how do you clean it? If it was supply steam, that would be pretty clean. But exhaust steam has the cylinder oil in it. How is that routed from the exhaust flow?
-ken cameron
Berkman
Post by Berkman »
The exhaust steam and cold/hot water don't mix in an elesco like this.
There is another cylinder/tank surrounding this internal bundle, and that's where the exhaust steam is routed. This final "tank" is the tank you see when you look at a locomotive with an elesco.
Elesco FWH.jpg (23.59 KiB) Viewed 12150 times
kcameron
Post by kcameron »
Berkman,
Too bad that's a jpg as it doesn't scale up to get the details clear. But I think I see that the other assembly sits inside the larger cylinder which is getting the steam around the whole thing.
If enough progress photos are posted it should be easy to see how this comes together.
-ken cameron
Berkman
Post by Berkman »
Ya, it was the best I could find online, agree, really look forward to seeing more progress photos.
Honestly, on a model, you probably get as much if not more feedwater heating by adding 5-6 coil loops inside the smokebox as several have done, but its amazing seeing this built!
little giant
Drilled the inlet/outlet holes in the fixed end of the feed water heater.
