I purchased a Miller Sycrowave 250 at auction from a trade school. Very good condition and appears lightly used. However, it didn't come with a tig torch or foot control. I see plenty of touches on ebay but the Miller Rfsc-14HD is pretty pricey. I did finally find another from USAWELD for about $100 less that they claim works with this machine and my Miller EconoTig. It does have the 14 pin connector.
It also had a much lower profile which I like. I find it kind of awkward to use the taller Miller while standing. Like to keep my heal on the floor at least.
Any opinions on using any of these third party foot controls??
Tig foot control; Miller or USAWELD
Jet vert Mill, Champion 12X30 lathe, Amer. Mach. Tool radial drill, 24X60 LeBlond lathe, Scharmann 3" Hrz Brg Mill, Steptoe 18" Shaper, S/B Shaper,B&S (No.4 36") Gear Cutting Mach., Verson 22.5T Press Brake, Enco 12" hrz. saw, McEnglevan foundry furnace, Rockwell 14X42 lathe, K&T 2H univ horz. mill,DoAll 16-2 Vrt. bandsaw,Canedy-Otto drill press,Buffalo Iron Worker
Re: Tig foot control; Miller or USAWELD
I don't have any experience with the options, but I heartily agree with you on the clumsy size of the Miller pedal. I would need a boot like Ace used to wear on my left foot to position my right foot properly on the control while standing.
a quick check of sewing machine pedals and a ohm meter may turn up a usable suspect at a thrift store. what I used for my miller tig
