I have been bending and shaping sheet metal and fabricating minor brackets for car and motorcycle projects, and now am contemplating getting a Lathe & Mill to step up my capabilities.
I do however need to have a 16mm partially threaded bolt turned down to 14mm x 1.25 (spark plug threads) for ~1.5 inches, and a plate made for locating/guiding the drilling/milling of dowels for locating cylinder heads on cylinders precisely.
I figured that I could watch the setting up processes and learn and see if it is something I really want to do while asking questions.
As I said, I'm in Marietta, but would travel a reasonable distance for the opportunity to pay to learn something and get something done that I need rather than just paying a machine shop to do it and learn nothing.
Any takers?
Lathe & mill services needed - Marietta, GA
Re: Lathe & mill services needed - Marietta, GA
Hello Brad,
I'm in Savannah, maybe too far, your call.
I can't cut metric threads on the lathe, would a die be OK?
Click on my name and drop me a PM if you like.
thanks
thanks
I'm in austell and my shop is in snellville and I can do limited metric threading although dies are easier. Let me know if your still interested.
