Kimball, I'm not concerned about that, that center section has a lot more machine work to be done on it, and should be a lot lighter when it's done...Kimball McGinley wrote:I hope that solid block works for you. I made a G-scale steamer with a hunk of aluminum for a cradle; the steam passages were drilled into it. All that ever came out was water, all that metal sucked out all the heat! One WAG suggested building a fire under both ends of the boiler!
Andy/Paul, I'm planning on it, but I think it's the weekend before the TCA show and I'll be there for that. I don't know if I want to make that trip two weekends in a row... But we'll see..
John
