Steam railroading to return to Alaska!
Re: Steam railroading to return to Alaska!
Dick:
Amazing to see your group's process over the years. BTDT.
A tale of perseverance!
Dick_Morris
Post by Dick_Morris »
The July status report is at http://www.alaskarails.org/pix/former-l ... index.html.
I'm glad the brakes on our models aren't this complex!
LVRR2095
Post by LVRR2095 »
It looks like you’ve changed from the original 6 ET brake to a self lapping 26L set up.
Keith
Dick_Morris
Yes. This is being done to make it compatible with positive train control.
That is beautifully implemented plumbing!
Gra2472
Post by Gra2472 »
I agree with RussN. Wow, whoever did the plumbing must have some incredible talent. This is really exciting to see a locomotive overhauled from the wheels up. No disrespect, but I hope you have an engine crew that reflects the time and work that your shop has put into the locomotive. As an old engineer from the Southern Pacific that trained me once said, “Treat her like a lady, work her like a….ahem……..w….re.” I hope to see video of this locomotive barking her way through Alaska soon.
7.5" Allen Mogul
The railroad is almost done.
G. Augustus
Monte Rio, Ca.
Dick_Morris
Credit for the the upgrade of the brake valve including the piping goes to Paul Dalleska.
We expect the volunteer overhaul crew will continue to be involved after she goes into operation. They all have several years of their lives invested so have a vested interest.
Indeed it will be good to see that locomotive steaming again.
I first saw it at Monte Holms collection in Moses Lake, WA, if I remember correctly.
I was trained to run steam by a Great Northern Engineer, James Norvell.
He told me "Fire her hot, and run her gracefully."
Words to live by.
Dick_Morris
The newest status report is at https://www.alaskarails.org/pix/former- ... noxEJQ-Zxc
One improvement we are making is to install aluminum shields with seals to protect the driver bearings from some of the contamination that blows around under a steam locomotive. Another is to add a thermocouple to each of the eight main and two leading truck bearings so their temperature can be monitored from the cab. The tender bearings shouldn't need much maintenance, we converted them to roller bearings.
Wise improvements!
Dick_Morris
The latest status report is posted at https://www.alaskarails.org/pix/former- ... index.html
Wonderful progress being made on #557!
Looks like quality work too. The future looks good.
