Prototypical looking hydrostatic lubricator?
Re: Prototypical looking hydrostatic lubricator?
The logging locos I ran all used Detroit lubricators: 3 outputs for most locos, and 5 outputs for the Mallets.
We always carefully followed the draining protocols before opening them up to refill, and never got showered.
We could see the stains on the cab roof where other operators made mistakes. That served as a warning for the rest of us.
Berkman
Post by Berkman »
Most air pumps got air operated lubricators on them, certainly almost any compound pump I've seen has a mechanical air operated lubricator of some kind on it.
I think making an air operated 1.5 scale air pump lubricator would be a nightmare to keep it reliable etc, but it would be neat if someone made a hydrostatic waterpump/air pump lubricator that looked like the air operated mechanical ones.
E6s 68
Post by E6s 68 »
To all,
I have attached a photo of a full size 3 feed Detroit 22 hydrostatic lubricator and a working 1.5" scale ready for assembly and testing. The casting set contains 8 bronze and brass castings. I will offer the casting set with plans for the build as originally by Saturated Steam if there is sufficient interest.
Sending a PM would be helpful. Thank you.
E6s 68
Sandiapaul
Post by Sandiapaul »
Interested
Andypullen
Post by Andypullen »
I have seen the one in E6s 68’s locomotive. The photos don’t do it justice!
My name is already on the list for one to go in the cab of my 92.
Andy Pullen
