Cylinder Passageway Designs with Slide Valve
Moderators: cbrew, Harold_V
DesignerIn3D
Post by DesignerIn3D »
I'm working with a 1904 Baldwin cylinder drawings that provides the classic three views of the cylinder. I'm attempting to draw this in 3D CAD.
My question is regarding how the live steam passageway is designed/formed from a.) the inside edge of of the port to b.) the branch of the Y.
I see the internal walls between the live steam and exhaust and it would be nice to have one in the shop to examine.
Where might I might images or other 3D perspective drawings of these passageway areas? Do any exist in museums that are cross-section cut for display? Any laying around a junk pile somewhere?
Gra2472
Re: Cylinder Passageway Designs with Slide Valve
Post by Gra2472 »
Maybe order a casting from a live steam supplier and cut it apart with a bandsaw?
7.5" Allen Mogul
The railroad is almost done.
G. Augustus
Monte Rio, Ca.
Builder01
Post by Builder01 »
Gra2472 wrote: Wed Jul 21, 2021 3:37 pm Maybe order a casting from a live steam supplier and cut it apart with a bandsaw?
Except, many cylinder castings do not have the ports cast in.
If you want to see how steam cylinders are ported, look at any mechanical drawings for them. if you are not able to read drawings, I'm not sure what to do to help you.
I made my cylinders from drawings, seemed pretty straightforward.
SteveR
Post by SteveR »
I have an Allen Models cylinder casting that is scrap. $50 plus shipping?
SteveR
12x36 Enco Lathe, 9x42 Bridgeport, SMAW, O/A, Miller MIG w/gas, plasma
Not enough measuring tools...
1.5" Allen Models Consolidation on air.
1" FEF in progress
1" & 3/4" LE Projects
I'm thankful that metal is recyclable....
Post by Bill Shields »
Is this a design exercise or something you are going to build?
Marty_Knox
Post by Marty_Knox »
Do some real research - find a copy of a Locomotive Dictionary or Locomotive Cyclopedia.
They have the illustrations you are looking for.
Steamtown in Scranton has a cut away 0-6-0.
ChipsAhoy
Post by ChipsAhoy »
Designerin3d:
I have 3d drawing of a cylinder composed with OnShape in an *.stl format. It has all the passages and bosses on it. You may be able to open it and edit it or at least open it and view it. I drew it up based on the MEG Wendy design, which is only different from the Allen design in dimension. After drawing it up I printed it out to use as a pattern to have two cast. In my case It was much cheaper, easier and basicaly pain free to purchase and use Allens. Steves are much improved over what Gene used to deliver (I have both). Pm me with your e-mail and I, hopefully, can forward it to you. If you are using OnShape I can give you direct access. I will try to post it here if I can figure out how.
Scotty
ChipsAhoy
Post by ChipsAhoy »
I converted these to JPEG to make it easy to copy and paste. that should give you a rough idea.
Builder01
Post by Builder01 »
I suspect the original poster is another tire kicker. Has not even been back to the forum since he first posted.
ChipsAhoy
Post by ChipsAhoy »
Thought it sounded kinda like a rudimentary question.
Post by NP317 »
Builder01 wrote: Sat Jul 24, 2021 10:26 pm I suspect the original poster is another tire kicker. Has not even been back to the forum since he first posted.
Only 4 days ago. Give him a chance...
