Does anyone rebuild Mosley Generators?
Moderators: cbrew, Harold_V
Yak18pilot
Post by Yak18pilot »
I have a 1.5" scale Mosley generator in which the dynamo part appears to be frozen. Is there anyone out there rebuilding these?
Thanks in advance!
hoppercar
Re: Does anyone rebuild Mosley Generators?
Post by hoppercar »
I replaced the bearings in mine years ago...been working fine ever since.....what is wrong with yours ?
Yak18pilot
The generator shaft (on the right had side of the photo) is frozen and will not rotate. It also appears as if the generator may be rusted into the housing. I would appreciate a source for new bearings.
Thanks!
Greg_Lewis
Post by Greg_Lewis »
My first stop for stuff like this is McMaster-Carr. They have some stainless bearings that might be good for this, and some that are more corrosion resistant than standard. You might take a look.
my2cents
Post by my2cents »
For those with more experience than me out there, is that a Mosley generator or one from LS or a homebuilt using the dummy castings that have been available? That looks like a electric motor in the housing. My understanding is that Mr Mosley used 3 phase rotor / stater.
Yak18pilot
This one is a Mosley as it's got an MO-6 plate on the top of it.
Rich_Carlstedt
Post by Rich_Carlstedt »
Not exactly sure what Moseley used if they were stainless and whether they had shields or seals ?
The bearing size is a R 2 and a R3- and the R3 is a flanged bearing
I believe (?) the Barden numbers are SR2ss and SFR156ss for shields , and maybe ff for seals
Rich
Yak18pilot
Thanks;
I may try to overhaul it this winter if I have time...
VO4454
Post by VO4454 »
A very good source of small bearings. Have used them for R/C glow engines.
Vic
https://www.bocabearings.com/
For Duty and Humanity
Thanks for the bearing link!
