The mounting for the scale whistle on my live steamer needs to have the threads chased, but I'm having a hard time identifying what size tap & die to obtain. By comparing the threads with other taps I have I've determined that it is 40 TPI, but don't know the size. I've attached some photos of the dimensions. Hopefully someone can identify what size this is.
Thanks in advance!
Need Help Identifying Tap & Die Size
Re: Need Help Identifying Tap & Die Size
1/4-40 ME (model engineer) is my best guess.
Is the thread tapered? With the end tilted towards the camera the thread looks straight or parallel. If it's tapered it would be a 1/4-40 Model Taper Pipe or MTP.
Less likely-
There's also a UNS Unified National Special or UST Universal Straight or Tapered which I believe will fit the others.
Denny
Less likely-
Denny
"Measure twice, curse once."
here is a source
https://www.pmmodelengines.com/shop/too ... taps-dies/
from the pictures, it appears to be straight cut threads.
- Dick_Morris
The whistle and elbow commercial fittings are probably MTP. If so, it would be logical for the builder to follow suite with other threads on the piping.
With a cast elbow my initial thought would be that it's MTP, but I don't see a definite taper on the thread, so I would then think 1/4-ME.
But something else bothers me about the installation. As I see it, it's mounted in a very precarious position where if accidentally bumped or tugged on when in steam, the pipe connection could be broken by the pipe acting as a lever. If it were mine I would shorten both pipes, especially the horizontal one, so as to reduce the potential for accidental breakage.
Perhaps a dome cover we don't see protects the pipes as well as prevents shortening.
GWRdriver
Nashville TN
Nashville TN
Thanks for the help!
There's a steam dome cover that I have removed to gain access to the safety valves so the pipe for the whistle is protected for most of its length
with GWR on this...accident looking for a place to happen....heck, just pulling on the whistle lanyard could snap it off...
