I may get them to mount under the firebox propane burners of my two locos.
Re: looking for long life light bulb
Posted: Fri May 14, 2021 5:24 am
by Bill Shields
Those burners will not fit thru firedoor
Posted: Fri May 14, 2021 8:19 am
by ctwo
I figure by the 4th page, you guys have fingered a solution, and I know some on the board are not a fan of conspiracy theories, but this one is pretty good...
Posted: Fri May 14, 2021 10:03 am
by NP317
Bill Shields wrote: ↑Fri May 14, 2021 5:24 am
I suspect you're already aware of these, but if not then you may want to take a look at the 75W 120V 2-pin halogen T4 bulbs and their bulb-holders. I used to use one of those inserted through the firehole door before I switched to the magnetic heaters. They give off a lot of heat for their small size.
