Page 2 of 4
Re: Trying to do a leak down test on my cylinders.
Posted: Sat May 01, 2021 10:02 am
by Emfinger
Gra2472 wrote: ↑Sat May 01, 2021 7:22 am
Sounds like you need to disassemble it completely and have a good look around. If it won't move under 100 psi then you're not doing yourself any favors trying to force it.
Nothing is being forced. I just want to see the piston move via air pressure.
Posted: Sat May 01, 2021 12:03 pm
by Bill Shields
Can you rotate the wheels a full 360 degrees with no air pressure applied?...
Before you do any pressure tests you need a freely rolling drivetrain
Posted: Sat May 01, 2021 12:25 pm
by Emfinger
Bill Shields wrote: ↑Fri Apr 30, 2021 4:51 pm
you would not expect the piston to move if the wheels are locked...
however...if you are moving the valve rod (by hand) and getting no reaction whatsoever from the piston, then I would suspect that there is a problem with the valve...maybe totally disconnected from the valve rod...
or stuck up and away from the valve surface (for some reason)....
however if the valve is away from the surface then you would be getting all your air straight out the exhaust pipe...
I would start by taking the cover off the valve chest for a look-see
note of caution:
If things don't work as expected at 10 psi..putting 100 psi on it is not going to tell you much more. Should things get away from you at that pressure..things are going to start happening in a big hurry.
OK top coming off today.
Posted: Sat May 01, 2021 1:18 pm
by hoppercar
Your putting air into the steam chest....you can rock the drivers back and forth, and you say at no time, is the piston under pressure ??.....either your port spacing is wrong, and your not admitting air to the cylinders, or your passageways to the cylinders are blocked, not letting air into the cylinders
Posted: Sat May 01, 2021 2:00 pm
by Bill Shields
Occum's razor...the valve is stuck?
Posted: Sat May 01, 2021 3:54 pm
by Emfinger
OK guys I ran the engine just days before I tried to do a leak down test. I'm testing because I feel the torque is uneven and a little on the light side. I'm way past any zebras, and I do agree with Occum.
I have torn the whole damn thing apart. I know the left front never saw any pressure..PERIOD.
The bore could use a good hone job, just for S&G. This Stephenson Linkage system is OK, I guess, but the slide valve is a poor design. Is there anyway I can change to a more positive valve system? I don't understand how this damn things seals.
Tom
download/file.php?mode=view&id=83769
Posted: Sat May 01, 2021 4:30 pm
by hoppercar
The valve should not be a tight, or , snap fit on the valve stem....it needs to fit loosely with a few thou, clearance.......it has to be able to move on the valve stem, so steam pressure, keeps it pushed down on the valve seat...
Posted: Sat May 01, 2021 8:38 pm
by Bill Shields
So it ran but you feel uneven...weak on one side..and you are sure that the valve settings / travel are the same on both sides...?
This is not an easy thing to check on Stephenson gear..and you admit that your experience in these matters is limited...something as simple as a slipped eccentric is very difficult to check.
Careful with honing with a spring loaded automotive type of hone. Best to to it...if needed..with a lap or sunnen type of hone if a available.
Rings or seals on the pistons are what? Cannot tell from the photos.
Posted: Sat May 01, 2021 10:59 pm
by NP317
If you can post pics of the slide valve surfaces and system that would help us understand the situation.
I do note that the ports from the valves open to the front and rear of the cylinders through 5 holes.
And it looks like the head seals may be o-rings (?) which will block the connection between those 5 ports and the cylinder ends.
Better pictures will reveal more.
If the cylinder head gasket seals those passages, then no steam/air will get to the pistons.
Posted: Sun May 02, 2021 6:55 am
by David Powell
Looking at your photos it seems that the end cover you show completely blocks off the 5 drilled holes when bolted up. Perhaps the builder simply forgot to mill a way through for the steam. Try taking the end cover off the good cylinder and comparing the two. David Powell.
Posted: Sun May 02, 2021 7:15 am
by Gra2472
Looking at the photos, it is difficult to make a specific diagnosis. I would like to see the steam side of the cylinder head, and the valve and valve face. But, I can agree with David and np317 that it appears that the steam ports are sealed from the cylinder when the cylinder head is on. I cannot see a passage from the 5 ports to the cylinder. It looks like this is a homegrown design that may not have been finished.
Posted: Sun May 02, 2021 7:28 am
by makinsmoke
It was running, guys.
