Simple Oscillating Steam Engine For Beginners
dampfmann
Post by dampfmann » Thu Apr 29, 2021 7:13 am
I am looking for suggestions of simple oscillating single cylinder steam engines with plans as a beginner shop project. I've looked across the internet and there are several examples, but has anyone on the board actually built one of these models? Any tips?
Thanks,
Marty
rmac
Re: Simple Oscillating Steam Engine For Beginners
Post by rmac » Thu Apr 29, 2021 10:45 am
I made an extremely crude oscillating cylinder engine a few years back as an exercise to see what I could do with recycled HDPE plastic. It ran successfully on compressed air right after I finished it, but over time the plastic parts warped enough that it bound up too tight to run.
There's a video of it running here:
https://www.youtube.com/watch?v=7vhQVH1eITY
As far as tips go, just pick one and go for it. They're simple and easy to get running. (And make it from something other than HDPE!)
-- Russell Mac
Post by John Hasler » Thu Apr 29, 2021 11:23 am
Did you anneal the HDPE?
rmac
Post by rmac » Thu Apr 29, 2021 11:31 am
No. I cast it into blocks and then machined the engine parts from them. How would you go about annealing it?
-- Russell Mac
Post by John Hasler » Thu Apr 29, 2021 1:12 pm
rmac
Post by rmac » Thu Apr 29, 2021 1:28 pm
How about that! Thanks. Sounds easy enough unless some precise control of the heating and cooling rates is critical. My HDPE "foundry" consists of a $10.00 thrift shop toaster oven with a questionable thermostat. On the positive side, it keeps the HDPE out of the oven in the kitchen, which in turn helps to maintain domestic tranquility.
-- Russell Mac
Steamer Al
Post by Steamer Al » Thu Apr 29, 2021 4:54 pm
"Making Simple Model Steam Engines" by Stan Bray has some good designs for engines, boilers, and pretty much everything need to get started. Also has good how-to intructions for his designs. I do find some of the stuff a bit crude, but with a little imagination you can take the designs and make something quite pretty.
Alex
FKreider
Post by FKreider » Thu Apr 29, 2021 10:04 pm
Google "elmer's engines" lots of very simple plans. I just recently completed Elmer's Fancy oscillating design.
-Frank K.
