painting Fiberglass tender shell
Postwarbob
Post by Postwarbob » Mon Apr 05, 2021 11:49 am
PREPPING fiberglass for rattle can finishing . I am looking for info on painting a fiberglass tender. Do you scuff with sand paper , then spray primer and then the finish coat. I plan on using Rust O from Ace Hardware . Thanks for any ideas on this process . Bob...
Bob D.
Re: painting Fiberglass tender shell
Post by Bob D. » Mon Apr 05, 2021 12:34 pm
Make sure you de-wax it well to remove any mold release. Wipe down with acetone.
3/4" Juliet II 0-4-0
3/4" Purinton Mogul "Pogo"
3/4" Hall Class 10 wheeler
3/4" Sweet Violet 0-4-0
3/4" Hunslet 4-6-0
1 1/2" A5 Camelback 0-4-0
Glenn Brooks
Post by Glenn Brooks » Tue Apr 06, 2021 12:52 am
Fiberglass is pretty forgiving/accepting of paint. Definitely you will need to wipe down the surface with acetone, before the undercoat.
Also,easy enuf to mix a color into your finial coats of resin.
jcfx
Post by jcfx » Tue Apr 06, 2021 11:25 am
Agree on removing any wax mold release, one exception is if you used PVA as a release, just wash it off
with warm water and a even light scuff of the surface and you're good to go for primer.
I've always liked high build auto primer.
milwiron
Post by milwiron » Tue Apr 06, 2021 3:32 pm
Prep-Sol by Dupont is an excellent prepaint cleaner that removes silicone based releases, wax and oils of all types. Prep-Sol can be found in auto parts stores and auto paint dealers.
Any pics of your tender?
Denny
"Measure twice, curse once."
