First Test of a DIY Steam Turbine running off a 4" Copper MSM Boiler.
https://youtu.be/dAtLPlYfpyA
- Jim Dobson
Re: First Test of a DIY Steam Turbine running off a 4" Copper MSM Boiler.
Obviously a lot of fun, and careful work. Perhaps it would be interesting to see it driving something, maybe a propellor in a tank of water, and compare it with the performance of a conventional engine doing the same job, steamed by the same boiler and burner combination.
Regards David Powell.
- Jim Dobson
Thanks David, its been ridiculously hot since I finished this and have had only limited time in my shed. I did hook it up to a DIY genny and it lit a bank of globes very easily. There's a fair bit of internal centrifugal weight when its up and spinning, but it won't have the same grunt as a steam engine.
It would be even more interesting to see the insides.David Powell wrote: ↑Thu Dec 17, 2020 3:25 pm Obviously a lot of fun, and careful work. Perhaps it would be interesting to see it driving something, maybe a propellor in a tank of water, and compare it with the performance of a conventional engine doing the same job, steamed by the same boiler and burner combination.
- Jim Dobson
Its pretty simple inside, I made the vanes out of quite thick copper sheet and they are very heavily silver brazed into place on the brass section to with stand the force on them. I think I might have to invest in one of those el cheapo digital tachometers on eBay as I would like to know the rpm's.John Hasler wrote: ↑Thu Dec 17, 2020 5:07 pmIt would be even more interesting to see the insides.David Powell wrote: ↑Thu Dec 17, 2020 3:25 pm Obviously a lot of fun, and careful work. Perhaps it would be interesting to see it driving something, maybe a propellor in a tank of water, and compare it with the performance of a conventional engine doing the same job, steamed by the same boiler and burner combination.
Hooked it up a little while ago to a small DIY genny and it lit up a gang of light bulbs without a problem.
