Derailing 2-4-2 7.5" 1.6 scale
Emfinger
Post by Emfinger »
Hello, I have a 2-4-2 Columbia that likes to derail the tender, sometimes the leading axil, sometimes the trailing axil of the engine, but most often the leading truck on the tender. It seems to happen at the same spots but not always. Others don't seem to have the problem. I have serviced the trucks and don't see anything wrong but ???
Some say I should be able to lift one wheel 1/4" off the track without other wheels lifting. I can lift mine 1/2" without others lifting.
Thank you for any help
Tom Emfinger
Marty_Knox
Re: Derailing 2-4-2 7.5" 1.6 scale
Post by Marty_Knox »
Check your drawbar. If it's too tight it will cause the problem you're describing.
I agree with Marty: Drawbar issue.
Emfinger
Post by Emfinger »
Interesting, the drawbar is tight. It is made from two heim joints connected with coupler. What would you use?
Tom
ccvstmr
Post by ccvstmr »
Em...nothing wrong with Heim/rod end ball joints. Have had such a draw bar between my loco and tender for years. Put those in to solve another issue. Question...do the balls pivot easily in their housings? Is there something else preventing the drawbar from moving enough up/down and side-to-side without obstructions?
If necessary, get down on the ground and watch what the wheel sets/trucks are doing thru the problem spot you identified. There's gotta be a reason why things are coming off the track. It's going to take some close observation to find the cause. Good luck. Tell us what you find. Carl B.
Glenn Brooks
Post by Glenn Brooks »
I had a similar derailing problem with couplers. Always on curves. Usually at the same spot on curves. My issue was the coupler contacts were to tight, which pulled one of trailing car wheels up onto the rail, where it would eventually derail. When the rail ballast settled to much, that spot was prone to derailing. Both because of low rail height, and primarily, to rigid a coupler connection. I ground down my coupler arms, so they easily moved up and down when locked together. Solved the problem.
As others have mentioned, sounds like your draw bar attachment could/should be a lot looser. Also check how level your track is, at those spots were your loco derails consistently. (Both Cross wise and length wise)
Emfinger
Post by Emfinger »
Yes, I'm sure the joints are too tight, they are small, I'll check for freedom.
Thanks guys
Tom
kcameron
Post by kcameron »
Another case I've heard of derailing was a loco where the springs didn't put the weight in balance on the rails. The pilot truck was very light on one side and heavy on the other. It did fine on the track but came off when hitting a curve in only one direction. They adjusted the springs to get the weight even and it ran fine after that.
-ken cameron
Syracuse Model Railroad Club http://www.SyracuseModelRr.org/
CNY Modelers http://www.cnymod.com/
Finger Lakes Live Steamers http://www.fingerlakeslivesteamers.org/
Member JMRI Developer Team http://www.jmri.org/
mailto: kcameron@twcny.rr.com
In the Upstate New York US area of the world
Dick_Morris
Post by Dick_Morris »
The locomotive might not be the only cause. Have you checked the track in the places where you derail, particularly for changes in cross-level?
