Decauville 0-4-0 1:22.58 Scale
Re: Decauville 0-4-0 1:22.58 Scale
I was kind of hoping to join ALS ,retirement and Florida came up first. I do not believe there is a club close that may have a high line for me to play on when I am finished. Oh well, it looks like I will just have to find a big boy to work on.
It is good to get on here and read all the good stuff.
I am finished with my build, and I am very happy with the outcome
Great looking engine!
Now you just need to build an identical one in 7.5 gauge!!
- Benjamin Maggi
Looks nice indeed!
I am impressed! Looks like you got the boiler sorted out, and everything went together pretty good. Now, you gotta show us some pictures of it under steam. What is the fuel used?
Thank you everyone, The fuel is LP.
- Steamer Al
Great little locomotive! You must be very happy with it.
Just curious where you got your pressure gauge from? I'm looking for some around that size and I like the brass rim.
Cheers
Alex
Cheers
Alex
Excellent work!
The little locos are just as much fun as the big ones.
Build your own track now.
PLS has a 2.5" gauge track.
Granted...it is a ground level track... but rails are rails. And the older we get the more attractive smaller engines become
Sorry, Have not been on here.
The gauge I found from an old pressure regulator. I drilled a hole in the bottom of the connection and silver soldered in the copper line.
I started building a log car for the bugger, something to do LOL
Hi Everyone, I was a little board so I found a drawing of a wood wagon to build to pull behind the loco pic attached. I took all the dimensions and times them 1.41, scale came out nice!
