3/4" scale rolling stock and trucks
Dick_Morris
Re: 3/4" scale rolling stock and trucks
Post by Dick_Morris »
I recall someone experimenting with plastic trucks and wheels for non-load bearing service in 3/4".
It would have pre-dated consumer 3D printers, but I think the late Miles Snyder made a fleet of four-wheel coal cars in 3/4" or 1 " scale with plastic running gear. He mentioned working on them during a long-ago trip to Alaska but they may have also been mentioned in Live Steam.
tsph6500
Post by tsph6500 »
Steve Bratina made a very nice boxcar kit a couple of years ago.
Best regards,
Jim Leggett
Montreal Live Steamers
www.montreallivesteamers.org
A Founding Member of the Tinkerbell Scale Society - Northern Division
I'm an A.R.S.E. (Association of Railroad Steam Engineers)
Toad Swamp & Punk Hollow Railroad - Head Tycoon
The Juvenile Traction Company - CEO & Apprentice Machinist 3rd Class
White Mountain Central RR - Engineer & Fireman
SteveR
Post by SteveR »
Since this is the most recent thread on the topic, I'll post this question here. I'm building some of Jim Abrams' trucks and was looking for someone who has also built them.
In this thread: viewtopic.php?t=87904 are some nice pictures of these trucks when completed as shown here:
You can see in this picture that the bolster appears upside down (flat surface down) compared to the drawing that I have. There is a note saying "Side frames must be free to pivot, but not shake". So does this mean that the bolts holding the side frames to the bolster have allowed the bolster to flip upside down in the pictures, but that when connected to an undercarriage, the bolster will be rotated?
I reached out to Jim, but he may be busy. And better to post anyway for others with the same question.
Thanks,
SteveR
Not enough measuring tools...
1" FEF in progress
1" & 3/4" LE Projects
I'm thankful that metal is recyclable....
FKreider
Post by FKreider »
SteveR wrote: Sat Feb 06, 2021 1:48 pm So does this mean that the bolts holding the side frames to the bolster have allowed the bolster to flip upside down in the pictures, but that when connected to an undercarriage, the bolster will be rotated?
Yes that is exactly what you are seeing- flat surface goes up so that you can access the bolster/side frame bolts from the bottom of the car.
-Frank K.
elm53
Post by elm53 »
The flat side of the bolster is up.there are two small rollers or two "buttons "that are side bearers for the car that allow some additional flexibility .
SteveR
Post by SteveR »
Awesome! Thanks!
1" FEF in progress
Post by Bill Shields »
Jim's trucks are great. They are based on a Purintin practice of truck building. I have used this concept for 40 years in 3/4, 1 and 1.5 inch and am very happy in all scales.
Trucks are very stable...you do not feel like you are floating.
Note
.Charlie Purinton used to build the side frames from wood. He also used screen door hooks for couplers but that is off topic
SteveR
Post by SteveR »
Bill,
It might be off topic, but a good new topic nevertheless. Suggested topic title: "The Purinton practice of truck building"?
Thanks
SteveR
1" FEF in progress
FKreider
Post by FKreider »
Its been discussed in other threads however I will repeat the info here as the old topic is buried somewhere in this forum:
The trucks that Jim sells are exact copies of original Bill Van Brocklin patterns and design. The reproduction match plate was made by DMS.
Whether or not Bill VB based his design on a Purinton build practice I can not say one way or another.
These are the most simple and affordable trucks on the market for 3/4" scale. 8)
-Frank K.
SteveR
Post by SteveR »
Finally finished these:
Now I just need to finish rebuilding the 3/4 LE Northern that will pull them, along with a tender...
More fun.
SteveR
1" FEF in progress
Hmmmm...cart before horse?
SteveR
Post by SteveR »
I prefer "Be Prepared!" :D
1" FEF in progress
