3/4" OD copper K type tube Roller
Fender
Re: 3/4" OD copper K type tube Roller
Post by Fender »
Marty’s method worked perfectly for me. I only suggest the rubber mallet so as to not damage the end of the tube when pushing/wringing it into the firebox tube sheet. If you make both tube sheets with an oversize hole, it’s going to be a PITA trying to keep the tube from spinning when you go to expand it.
Dan Watson
Chattanooga, TN
Post by Bill Shields »
Depends on the misalignment ...and lubricant used
Jacob's dad
Post by Jacob's dad »
Marty_Knox wrote: Wed Jan 27, 2021 10:18 am I have always used 1/4 of the tube diameter. That would be 1/4" for a 1" diameter tube. Larger diameter tubes need a larger ligament.
I am just curious if that is the od or id of the tube?
Thank you,
Jeff
I have used 1/4 of the tube od
Marty_Knox
Post by Marty_Knox »
Jacob's dad wrote: Fri Jul 02, 2021 11:35 pm
Thank you,
Jeff
The OD of the tube.
