Steam turbine generator
Re: Steam turbine generator
Prior to the days of lithium batteries and brushless motors in the RC car world, I had played with winding my own armatures and also had a little lathe for the turning the commutators. I was able to statically balance the armatures by letting them rotate freely in the lathe on their bearings while applying a little PC-7 epoxy to the windings. It was not perfect, but got them pretty close. After it cured, it could be fine tuned by repeating the procedure again and removing a touch of the epoxy with a dremel. My '"speedway" wind ended up running almost 54,000rpm but at a lower amp draw than other off the shelf motors that my competitors couldn't make run time with. Coupled with a good setup, I dominated the open class, and the motor held together until I moved on from the hobby and it became obsolete.
The high efficiency of the new drone motors have lots of potential retrofitted into a steam generator case, I'll be watching this thread to see how it goes.
Btw, check out this on Ebay. Tiger Motor 1306's, 12 each for $250, over 1,300 in stock.
https://www.ebay.com/itm/233679735404?m ... aad8f50684
Apparently, there's now a way to dynamically balance motors (or generators) using a smart phone running a vibration app. I have only seen this demonstrated on the following YouTube video and have not used this method myself, but it looks very useful. I will certainly be giving this technique a try on my steam turbine before I spin it up to full rpm. https://www.youtube.com/watch?v=RItntpZZH4g
- Dick_Morris
Dusty Very interesting. Not only will this allow the generator portion to be balanced, but it makes the idea of an investment cast wheel a lot more achievable
Did you notice that the video is eight years old, so the capability has been around for a while. (But this is the first time I've heard of it.)
- Dick_Morris
I have been surprised that I hadn't been able to find good photos of a K-240 on the Internet, so for posterity and for the one or two people who might actually want to build one I offer up these photos taken at the ARR 557 Engine House this morning.
- Attachments
- Dick_Morris
This may be a situation of let the buyer beware. There are a number of vendors who list this motor but they are all out of stock. I have also read a number of posts saying that knock offs of the popular motors is rampant.Btw, check out this on Ebay. Tiger Motor 1306's, 12 each for $250, over 1,300 in stock.
I don't think I'd want to spin a casting up to the RPM these will see. Just my opinion. I think I'd want a machined billet part or a forging. Granted if it comes apart it's not likely to explode out of the case and injure anyone, but all the hard work turned into a paperweight wouldn't be so wonderful.Dick_Morris wrote: ↑Sat Sep 11, 2021 1:35 am Dusty Very interesting. Not only will this allow the generator portion to be balanced, but it makes the idea of an investment cast wheel a lot more achievable
If you feel the Ebay link motors are poor quality knock off's, please remove.
- Dick_Morris
Although it is a point worth considering, the turbine wheel on my generator will be less than an inch in diameter so the forces are comparatively small. Motors of this size drive a plastic prop at the same speed that are three inches in diameter which I have to assume are fairly reliable. I have thought about doing some testing of the design of a 3d printed turbine wheel but would turn it at only a small fraction of the design speed of the motors.
I don't know that there is a problem with the Ebay motors, and I wouldn't mind having a couple to test if I didn't have to buy a dozen, but I wanted to share the general caution on knock offs that I found in several places while doing my research.
Castings vs Forged metals; interesting sub-topic for this thread. In general, I agree that castings are weaker than parts made from forged metals, but that doesn't mean that castings are too weak to be used. Nearly all centrifugal impellors (aka Compressor wheels) along with the hot section turbine wheels found in automotive turbochargers are castings, which would seem to validate the use of castings in high rpm applications.
I've been through several turbochargers. The ones I worked on had a hot side wheel that was one part with the shaft, and appeared to be forged steel to me. There was a hex which had been machined on the top of the hot side wheel, and then part of it had been ground off to balance it.
The compressor side was aluminum and had an extruded look to it.
I have seen some others like the OEM Turbo used on the Cummins, which appeared to possibly have a cast hot side.
- Steamer Al
Also interesting to note that some of the compressor blades in modern high bypass turbofan engines on airliners are investment cast. Althought Im sure its an alloy we could only dream of getting ahold of!
https://www.foundrymag.com/molds-cores/ ... ine-blades
That hex is cast in. The investment casting foundry that my wife works at makes those turbo wheels, both ends.
You are correct about the cast turbine blades but any comparison of that process (or material) to any type if casting available to hobbiests is like comparing a Model T to the Space shuttle.Steamer Al wrote: ↑Tue Sep 14, 2021 2:33 pm Also interesting to note that some of the compressor blades in modern high bypass turbofan engines on airliners are investment cast. Althought Im sure its an alloy we could only dream of getting ahold of!
Nothing wrong with a correctly cast wheel.
