Friends models hudson
Recently picked up a part built friends models NYC hudson. Now being based in the UK it puts me at somewhat a disadvantage as to being able to see a complete example so if anyone has built one and could provide a few pointers and or advice of areas that may require modification . We don't know of another over here either.
Re: Friends models hudson
I built mine 40+ years ago and have a few pictures and not too many memories but will help in any way I can
Are you sure they are Friends / Langworthy design castings and drawings?
It is indeed a Friends/Langworthy designed engine quite how it came to be in the UK remains a mystery . Its currently on its way up from the South Coast and when it arrives I shall post photos
New or old castings..old as in 50 years or new as in produced within the last 5 years.
Checking again the castings have Yankee cast into them which may help age them and the rear truck is bronze
75 years back they were all iron... based on what I have seen ...which is the age of the castings I used.
In reality it matters not.
Did you get a tender water bottom with the set?
I have a part-built 5"ga Maid of Kent (LBSC) and how it got here is a curious story. I also have a Myford S-7 lathe and the story of how that came to me is stranger than fiction.Jordanleeds wrote: ↑Tue Sep 28, 2021 4:03 amIt is indeed a Friends/Langworthy designed engine quite how it came to be in the UK remains a mystery.
GWRdriver
Nashville TN
Nashville TN
The 1952-53 Yankee Shop Machinists catalog lists the following details for the Hudson:Bill Shields wrote: ↑Tue Sep 28, 2021 4:48 pm 75 years back they were all iron... based on what I have seen ...which is the age of the castings I used.
- Trailer truck side (Bronze) (2 required)
- Trailer truck rear beam (Cast iron)
- Trailer truck front beam (Bronze)
But like Bill said this matters very little. No mater what the material is the Yankee Shop/Langworthy truck looks far better than the old 3/4" Little Engines trailing truck design which I must say leaves much to be desired.
-Frank K.
Guess my castings are more than 70 years old...ugh..makes me feel totally ancient
The Hudson that I have that was built by Harry Hansen from New Jersey used castings that he bought from L.D. Langworthy in the 1930’s. The trailing truck frames are bronze, as is the cast tender bed.
Keith
Keith
