Page 3 of 16
Re: castings for the B&O P7d Cincinnatian
Posted: Wed Jul 28, 2021 12:53 pm
by Andypullen
Mike Walsh wrote: ↑Wed Jul 28, 2021 8:35 am
Andy R wrote: ↑Tue Jul 27, 2021 5:46 pm
Examining the drawings that I had, the complexity of some parts appeared too great to try and fabricate, so a few castings were obtained from John at Friends Yankee Shop. The Brake Hanger Bracket #4134 in particular was a bit of a puzzle regarding how to hold the casting while machining, and in what order the machining was done. Adding to the consternation is the dimensioning - all relative rather than from an absolute reference. All connecting parts had to be consulted. In addition to supporting the brake hangers, these also support the main equalizers.IMG_4199.JPG
I have elected to not (yet) finish any surface that does not need finishing. Paint will hide everything anyway.
Another casting set obtained is the brake hangers, part #8142. These are paired left and right. And holding them was also a puzzle.IMG_4197.JPG
I may thin the web to the dimensioned 1/16 inch, but at this time it appears unnecessary.
Andy, I might have some of these castings (surplus to my needs). I am not sure if they are 3/4" or 1/2" - inclined to think 1/2", but if they are 3/4" and useful to you, you can have them free of charge if you're interested. Can you send me a PM with a photo of the brake hangers and brackets with a 6" scale next to them and I'll look in my shop?
I might also have some of the parts that you need. PM me with photos also.
Andy Pullen
castings for 3/4-inch scale B&O P7d Cincinnatian
Posted: Wed Jul 28, 2021 6:16 pm
by Andy R
Mike and Andy,
Thanks for your generous offers!
PM's sent.
Regards,
Andy
A Visit to Baltimore
Posted: Thu Jul 29, 2021 10:06 am
by Andy R
I had an opportunity to go to Baltimore, so did not pass up a visit to the B&O Museum. I could have spent an entire day or two there, but spent most of my limited time documenting the 4-2-0 Lafayette. I may someday build a 3/4-inch scale version, but it has been significantly lowered in priority as a project. The surviving P7, the 5300, was stored in the parking lot of the museum, and appeared faded at best. I did examine the offerings in their bookstore, and purchased a copy of:
“Baltimore and Ohio’s Cincinnatian” by Thomas W. Dixon, Jr. published by TLC Publishing. ISBN 0-939487-85-1 (2008).
Wow. What a neat streamlined locomotive! I had recalled reading about it in “Steam’s Finest Hour” edited by David P Morgan, and published by Kalmbach Publishing Company in 1959. I have had a copy of that since I was young.
This is a copy of a B&O publicity photo from 1946.
The P7 has been modeled in 2.5-inch gauge, in 3.5-inch gauge, in 4.75-inch gauge, and in 7.5 inch gauge, and all that I know about have been of the as-delivered version from Baldwin in 1927. That’s understandable because it was a very nicely proportioned and decorated locomotive. But after reading Tom Dixon’s book, I thought “Why not make mine a little different?” I was sold on modeling the streamlined P7d, four copies of which were reconstructed by the B&O at Mount Claire in 1946. If anybody is aware of another live-steam P7d I will be interested in hearing about it.
Learning more about the P7d for the Cincinnatian
Posted: Thu Jul 29, 2021 10:14 am
by Andy R
Additional printed resources were eventually obtained in my effort to find out more about the P7d:
“STEAM LOCOMOTIVES OF THE BALTIMORE AND OHIO, an All-Time Roster” by William D. Edson, self-published in 1992, and
“Baltimore and Ohio Pacific Locomotives – Handsome Passenger Workhorses” by Bob Withers, published by TLC Publishing. ISBN 9780939487615 (2013)
The P7’s were modified extensively during their lifespans. One, the 5304, was streamlined in 1939 for the “Royal Blue” passenger train, and painted blue to match. That became class P7a. I have an American Flyer S-gauge model (#350) of that Dreyfus-styled locomotive. The streamlining on 5304 was later removed. The P7b really didn’t have any externally visible changes, but the P7c, P7d, and P7e modifications included a lot of upgrades including new cast-steel frames, Worthington feedwater heaters, air pumps mounted on the pilot, smokebox insulation, and more. It seems like they were all painted blue. The big difference in the P7d was of course the streamlining, and Timken roller bearings on each axle. The four modified into class P7d were the 5301, 5302, 5303, and 5304. They were assigned to a new passenger train (the Cincinnatian), and remained in service until 1957.
I won't be modeling the cast-steel frame under the locomotive - especially because most of the frame work has already been done. I also evaluated roller bearings and decided that they are not that practical (or needed) in this size. I may put roller bearings on the tender axles - still to be determined.
Equalizers and such
Posted: Tue Aug 03, 2021 1:22 pm
by Andy R
I have been working on suspension items. The attached photo shows the cross equalizer and (temporarily) attached spring yokes. These were hacked out of chunks-o-steel. It was time consuming but fun. Mr. Coventry in his original notes wrote: "...otherwise the whole job is straight-forward and only needs care and patience." So true! There are a lot of suspension parts to be made.
a gaggle of suspension parts
Posted: Tue Aug 24, 2021 6:54 pm
by Andy R
I have been making suspension parts, some of which have been temporarily attached to check fit-up.
In the photo are parts #1145, 2145, 3145, 6145, 9145, and 9145A.
I'm still working on the two trailing truck hangers #8145.
Starting fitup of the frame
Posted: Thu Sep 02, 2021 6:53 pm
by Andy R
The rear cradle fits well, square, and tight. Like the deck plate at the front of the loco, I left the bolts long thinking that I may need to over-drill and use nuts but everything was fitted well.
The same success was enjoyed with the mid frame spreader. The plans show this as solid but the x-bracing is much closer to the existing locomotive. But nobody will notice when the boiler is on.
This was my first mistake so far on the locomotive, which is surprising to me. (The first, not the mistake.) I located, drilled, and in some places tapped, 40 holes in the frame. On one side the 4 bolts for this were drilled and tapped 2-56 per plans, but on the other I drilled #30, because most of the other holes are #30. So there are 5-40 bolts on that side.
Tender Frame Fabrication
Posted: Thu Sep 30, 2021 6:12 pm
by Andy R
I have been taking my own advice and am working on the tender first.
I was unable to get drawings of the full-sized loco, even though knowing the drawing numbers. The B&O museum staff could not find the drawings - asserting that they were misplaced when everything had to be moved and conserved after the famous roof collapse. Someday they may be found, but I wanted to proceed. So I used the known dimensions from the B&O's line drawing, and a good friend drew up in the appropriate computer file format the new frame, extrapolated from the "standard" frame drawing.
The parts were laser cut - top plate and reinforcing frame below.
The first two photos show the top plate - after welding, and the last two show the underside.
I fabricated buffer beams, coupler and drawbar pockets, etc. from chunks-o-steel, trying to match the standard P7 frame, and bolted everything together. The deck plate and frame below were attached with 5-40 screws - countersunk - and then welded today by a professional welder. He only charged $10, and refused to accept any more than $20. Sweet. It is strong enough to support my weight standing in the middle with the ends supported.
This P7d frame is almost 3 feet long - and well beyond trying to patch two "standard" frames together.
If I wanted to really mimic the original cast steel frame I could make epoxy fillets between the plates.
Another reason to like 3/4-inch scale
Posted: Wed Oct 20, 2021 4:00 pm
by Andy R
For some reason, I forgot to drill and tap the frame at the Crosstie, Part No. 1134.
Maybe that's because I was a bit confused about its location and orientation.
(It will eventually be used to support the belly of the boiler.)
Not wanting to disassemble all that is already assembled too many times, I just picked up the frame and clamped it in the milling vise, drilled and tapped two 2-56 holes on one side, then turned it around and repeated the effort for the other side.
It all fit so well on the little Clausing mill. So what's not to like?
In praise of cast steel frames
Posted: Wed Oct 20, 2021 4:10 pm
by Andy R
Not particularly for model locomotive frames, but when held as described in the previous post, I realized why cast steel frames (from General Steel Castings) were so successful on full-size locomotives. They provided a lot more rigidity than the bolted frames.
This Pacific was the epitome of "Modern" in 1927, but it lacked significant torsional resistance in the horizontal planes. There is some horizontal-plane bracing at the pilot and the rear saddle, but not much in-between, where the drivers exerted significant wracking effort on the frame. There is mid-spam X-bracing to resist torsional strains, but not much in the horizontal plane.
In this scale I suppose that the cylinders might furnish more than enough resistance. It will be interesting to see how it works whenever I finish this beast.
Brake cyl's for 3/4-inch scale B&O P7d Cincinnatian
Posted: Tue Oct 26, 2021 6:13 pm
by Andy R
The dual locomotive brake cylinders are mounted just behind the main cylinders, and atop the frame.
The person who started this fabricated item made the mounting brackets too short in the longitudinal direction, and this was discovered after I had drilled and tapped the frame members to match the plans.
This photo shows the underside of the assembly.
The hole in the bottom is to attach the automatic drain cock when I fabricate it.
The legs, or tabs, that in the above photo are pointing up, are supposed to fit down between the frames.
I milled them off and then milled slots for new tabs, 7/8" x 7/8" x 3/16", and then silver soldered them in place.
The below photo also shows a view from under the frame, but now with long enough tabs, and drilled, tapped #2-56, and securely fitted in place.
The original fabricator had glued sintered brass cylinder liners that resisted pressing out, but the heat of the silver soldering destroyed the glue. That allowed polishing the liners on the lathe. I also trued the oblong pistons, fitted new springs, and it's "all done" waiting for test fit of the brake linkages.
Re: 3/4-inch scale B&O P7d Cincinnatian
Posted: Thu Oct 28, 2021 11:12 am
by JBodenmann
Hello My Friends
Nice work Andy. As is often the case when finishing something another has started, there will be surprises. Sometimes good, sometimes not so good. But wiggling out of a tight spot is what separates those who finish a project, from them that don't. We all make mistakes, this is where perservierence comes in, or in my case stubbornness.
Jack
