Allen models Fitchburg Northern build by first timer
mcjustis
Re: Allen models Fitchburg Northern build by first timer
Post by mcjustis » Wed May 12, 2021 2:03 pm
I finished up the journal box bearings this morning. Also was able to get the shaft made for the front end along with the front wheels. Next part will be the spring shoes. I should have some time to press the wheels onto the axle in the next day or so. Getting there.
Martin
Post by Bill Shields » Wed May 12, 2021 8:14 pm
I tend to leave wheels off of axles until I am sure everything fits....
it is not always safe to assume that drawings are totally correct (even those that have been around as long as Chloe)...
mcjustis
Post by mcjustis » Thu May 13, 2021 12:37 pm
Thanks for the tip. I'll wait until the main chassis is ready to get some wheels before I put any wheels on axles.
Martin
Berkman
Post by Berkman » Thu May 13, 2021 12:55 pm
Going to put steel tires on the drivers?
Post by Bill Shields » Thu May 13, 2021 3:45 pm
strongly suggest that route...less slippery....
mcjustis
Post by mcjustis » Sun May 23, 2021 2:19 pm
Got a little work done on the frame today. I set up both frames on top of each other and lined everything up. I drilled and tapped three holes in the extra half loop on the bottom of the journal box area. I also drilled and reamed holes for 1/4 inch dowel pins. That should keep everything all lined up until the frames are finished. I also milled the top edge of the frames just to be sure they are all the same height. I had added .010" on the top face and the the journal box faces before I cut them out on the waterjet.
Martin
