Elesco feed water heater
little giant
Re: Elesco feed water heater
Post by little giant »
Ok finished making the feet to the body yesterday. I am debating to silver solder them on or just leave them to be screwed on. I don't know how to get around them with the wrapper if I solder them. On the prototype they cut rectangular openings, but were they longer than the feet to slide over?
little giant
Today I did some silver soldering to add the exhaust fittings from the cylinders and a boss from appliances (air pumps, feed water pump).
little giant
Starting to attach the wrapper over the body. I used some steam gasket material for insulation if it helps. I made a fixture with 2 vee grooves spaced the same distance apart as the cover holes on the sides. Then I used 2 gauge pins that fit the id of the tapped hole placed in the vee and butt the body up against the fuxture. I carefully drill the tap drill for 0-80 screws. Move 1 pin to the next hole and rotate the body again and again 39 more times. Easy peaszy like Jack says.
little giant
A couple of shots of the attached wrapper around the feed water heater body sitting on top of redesigned feet.
Berkman
Post by Berkman »
curious to see how this has progressed. have you been able to test it yet?
little giant
Have been busy at work and haven't been able to get anything done at home.
