that's fantastic jack, I can't wait to see moreJBodenmann wrote: ↑Fri Jun 18, 2021 9:48 am Help My Friends
Thanks Dan. The waxes are at the foundry being cast in bronze. This foundry is really good, and his turn around time is usually less than two weeks.
Jack
3/4" Scale J1e
Re: 3/4" Scale J1e
- JBodenmann
Re: 3/4" Scale J1e
Help My Friends
Thanks Dan, I can't wait to see them too. I use a small foundry in Pinedale California. It's Valley Brass And Bronze. They only provide investment casting. And while we're on the subject of investment casting, here some tiny masters for hinges, and hasps. These will be needed for the full width turret casing. Probably also for the tender tank. The holes for the mounting screws are for #000-120 flathead screws. The hinge pins are .030". This is actually quite oversize as in 3/4" scale this is 1/2". These hinges would probably not have had 1/2" pins. The barrels that these pins fit through are 1/16" brass tube. Also very much oversize. I thought about making some smaller tube as it's only 3/16" long, but these little rascals are going to be delicate enough. They should be just fine. Sometimes I find it amazing that things this small will cast as nicely as they do. My 1-1/2" scale hinges and hasps have the same size barrels. These are some of the molds that were just made. Believe it or not these masters were almost too small for the #000-120 screws. I made the hinge body's to scale and then realized the screw heads might not fit. But they just barely did. A tiny countersink had to be made to clear the hasp clip. Just a small drill bit that was re ground. I find myself wearing the good Ol' optivisor a lot these days.
See You In The Funny Pages...
Jack
Jack
Re: 3/4" Scale J1e
Holy cows. You are on a whole nother level.
Re: 3/4" Scale J1e
I salute you!
How ironic that as we age, the BIG trains become more difficult to physically manage,
while our SMALLER trains become so much more difficult to even see!
And yet, we persist.
- Steamer Al
Re: 3/4" Scale J1e
Thanks for sharing your build! Its absolutley fascinating and very motivating. Every post keeps getting better and better!!
- Dick_Morris
Re: 3/4" Scale J1e
Wow!
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Thank you all very much for your compliments. I truly appreciate them. I really enjoy making little baloney like this. When making the little hinges it was definitely optivisor time. NP317 is absolutely correct. I sold my Number 9 because it was just too big. It weighed close to a ton. I have always liked 3/4" scale, it's just a hoot to build in. Nothing has been happening on the little Hudson lately as I have been working on revenue projects. Keeping the wolves off my doorstep and such. The rest of the week and probably next week will be working on a development project of mine. Something very, cool but I won't be divulging what it is until the first prototype is finished and tested. That is, until the fire door castings arrive Then it's playtime.
See you in the funny pages...
Jack
Jack
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
I went to the post office tonight, and waiting there was a small box of locomotive jewelry. As they say, good things come in small packages. Here are some if the things that were in the box. Three sets of fire door castings. I will be playing in the shop this weekend, putting one of these little rascals together. Too much fun. I can't wait to stick one to the back head of the J1e. There was also some other very cool little trinkets that I will be showing you soon. Something that most modern steam had scattered around. The Nickel Plate Berks had a gaggle of them. But you will have to wait a bit to see
Jack
Jack
Re: 3/4" Scale J1e
Ooooh. Jewelry!
Re: 3/4" Scale J1e
JBodenmann wrote: ↑Fri Jul 09, 2021 11:46 pm Hello My Friends
Jack
[/quote
- Attachments
- 15192753_10154095650293317_1943417567202931837_n.jpg (9.86 KiB) Viewed 4429 times
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Thank you Bill, NP317, and Dan. Today was one of them days when the planets lined up and most everything went well. That doesn't mean to say the little fire door didn't have me using Navy language a time or two. I called this little guy a rascal, and that is a pretty good term. There were some little pins to make for the door and manual lever pivots. These pins were .092 steel, and had had the "big" cotter pins, .020". So they required a #68 drill. In the top photo there is a simple drilling fixture that was used to drill the pins. First, a tiny center drill, change to the drill bit and drill the holes. Then the holes get chamfered to help the cotter pin find it's way later on. Next we have one of the pins for the clevis' that make it all work. This pin is .062" diameter, with a .125" x .020 head. This cotter pin is one of the "small" ones, .015". A #72 drill was used to make the hole. All these pins were made with L something or other leaded stock. Very nice stuff to work with. The last photo here shows the cotter pins .015", and .020". The difference is apparent and the small one scales out to a quarter inch. The big one scales out to over five sixteenths. Both are very oversize...but they will just have to do.
