3/4" Scale J1e
- Greg_Lewis
Re: 3/4" Scale J1e
Jack:
With the eyeball method, how are you figuring in shrinkage on the castings?
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Thanks for contributing Steam Engine Dan. Your J1e is really cool. That fire door is definitely a Standard door. Thanks Bill, how about posting a photo of your door. Here is a bit more on the fire door. Today I started on the operating cylinder and it's crosshead guide. Here the cylinder base started out as a block of brass. A couple different round nose end mills were used. Then the cylinder its self was made and they were stuck together with soft solder.
- JBodenmann
Re: 3/4" Scale J1e
Help My Friends
I just saw Greg's question about shrinkage. On something like this it isn't an issue. For instance, the 5/16" bore of the cylinder is only going to shrink about .002". Here is some more progress on the fire door. To the right of the piston is a sort of crosshead guide which the crosshead slides in. This was cut out mainly with a 5/32" round nose end mill.
- JBodenmann
Re: 3/4" Scale J1e
Here is the finished crosshead guide. And then a tiny little bit of tube. There are holes in the fire doors and the prototype had just plain holes without a raised lip. To me this just doesn't look right, they should have that detail. So these little bushings were made and set into recesses .070" deep. They are .090" tall, .115" OD. and the hole through the center is .079". I think they add a lot to the appearance. The oval around the lettering was made up from some half round that was made for some 1-1/2" scale cotter pins and the lettering is from a company in England. The prototype door had a lot more lettering. Patent information, casting numbers, and dates and such. I have some smaller lettering and I may add some, but not all that the prototype had. It still looks a bit plain and needs some clutter. The crosshead and it's link still needs to be made. Also the manual operating lever. The base plate also needs to be finished. In the past I have talked about if you make an incorrect mark you should remove it. I didn't follow my own advice and ended up cutting way too much off of the right side of the base. I hate it when that happens So some material will be stuck back on. I may also make the foot pedal that opens the prototype door but if I do it will be non functional. I hope to get this done and the molds made and then move on to something else. Maybe the booster and stoker engine. No shortage of things to do.
Jack
Jack
Re: 3/4" Scale J1e
JBodenmann wrote: ↑Fri Jun 04, 2021 9:10 am Here is the finished crosshead guide. And then a tiny little bit of tube. There are holes in the fire doors and the prototype had just plain holes without a raised lip. To me this just doesn't look right, they should have that detail. So these little bushings were made and set into recesses .070" deep. They are .090" tall, .115" OD. and the hole through the center is .079". I think they add a lot to the appearance. The oval around the lettering was made up from some half round that was made for some 1-1/2" scale cotter pins and the lettering is from a company in England. The prototype door had a lot more lettering. Patent information, casting numbers, and dates and such. I have some smaller lettering and I may add some, but not all that the prototype had. It still looks a bit plain and needs some clutter. The crosshead and it's link still needs to be made. Also the manual operating lever. The base plate also needs to be finished. In the past I have talked about if you make an incorrect mark you should remove it. I didn't follow my own advice and ended up cutting way too much off of the right side of the base. I hate it when that happens So some material will be stuck back on. I may also make the foot pedal that opens the prototype door but if I do it will be non functional. I hope to get this done and the molds made and then move on to something else. Maybe the booster and stoker engine. No shortage of things to do.
Jack
- Attachments
- 15192753_10154095650293317_1943417567202931837_n.jpg (9.86 KiB) Viewed 3842 times
Re: 3/4" Scale J1e
I continue to be amazed to see the pieces you create, and then remember that they are only patterns for molds for castings!
I don't have the mold making skills or access to lost-wax casting facilities. Or at least I've never pursued those capabilities.
Keep cutting...
Keep cutting...
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
First off, thanks again for the encouragement. Hey Dan, that photo of Jackie Gleason is a hoot. And thanks Russ. I am fortunate that my friend Brad showed me his mold making secrets. I also have an excellent foundry close by. Here is an update on the fire door. Some material was added to the sides of the base to correct my making it too small. Then a center for the rotary was made from 1/8" plywood. This allowed the work piece to be removed and then easy replaced on the rotary table. A 3/32" end mill was used to cut the slots for the mounting bolts. Then a 1/4" end mill was used to cut the recesses. It was then time to cut the outer perimeter of the base plate but it was late in the day and I was tired. I decided to head for my comfy chair and wait till morning to do this. I had already cut it too small once and didn't want to goof up again.
Happy model Building.
Re: 3/4" Scale J1e
me running from this past Saturday jack, ran 5344 for 9 1/2 hours on saturday. also attaching a couple of video links for you too.
https://www.youtube.com/watch?v=uPdcy0zHl7c
https://www.youtube.com/watch?v=-OT1o-WUQp8
3/4" Scale Standard Fire Door
Jack,
That Fire Door will also look great on my B&O P7d !
Make mine serial #2 please.
Regards,
Andy
Regards,
Andy
Re: 3/4" Scale J1e
Just for inspiration - here are the "small scale" butterfly fire doors that I have produced as investment castings. I originally designed them for my 3/4" Atlantic but they are also at home on many 1" engines. Mine are manual operation only - steam cylinder is just for looks - cant wait to see Jacks in operation!!
-Frank K.
- JBodenmann
Re: 3/4" Scale J1e
Hello My Friends
Hi Andy, there is a fire door with your name on it in the works. F Kreider, that is a very fine fire door!
Jack
Jack
Re: 3/4" Scale J1e
Yes, F Kreider that's a very nice looking fire box door. Jack, I am anxious to see how your door comes out. Are you thinking of offering them for sale?
