Page 2 of 2
Re: Power Drawbar
Posted: Sun May 02, 2021 8:28 pm
by Bill Shields
You are going to have to build a frame to support it.
Most Bridgeport's type mills have the belt system between two bearings...and there is a frame around and above the pulleys onto which this type of unit can be mounted.
Most mill drills have the belts as the upper most part of the machine with no frame above the pulley to which you can mount a power drawbar.
Yes...it can be done but is going to be a lot of work
Re: Power Drawbar
Posted: Sat May 08, 2021 8:47 pm
by c7z06
I use a right angle impact driver along with a right angle drill adaptor with a 3/4" socket. It was cheap and works, plus you can use the impact driver for other work, as needed. The trigger is up against the mill head, so a slight pressure activates it You can hold the driver near its bottom.
Re: Power Drawbar
Posted: Sun May 09, 2021 10:34 am
by NP317
THAT's a creative solution!
I've found several inexpensive power drawbar devices online.
But decided it is good rehab exercise for my rebuilt shoulder to manually do the job.
Re: Power Drawbar
Posted: Sat Dec 03, 2022 5:06 pm
by Fasturn
I have owned my share of BP mills but the Tree mill with the snap change was superior. For a home shop I have a spin handle to load and unload the collet. Speeds things up but if your trying to make money, the power drawbar is a must. Like the other post said " lot a sugar for a dime " if only a hobby shop.
Re: Power Drawbar
Posted: Sat Dec 24, 2022 10:33 pm
by Odyknuck
When I first bought my Mill 25 years or so ago, I also purchased an air butterfly kit similar to the OPs. It worked great for many years until one of the slider posts broke off. It was made of engineered plastic, tough however still weak for the intended purchase. I never fixed it or bought another. I actually removed the bracket last week as I was working on the mill anyways.
Re: Power Drawbar
Posted: Wed Dec 28, 2022 9:56 pm
by Odyknuck
Out of curiosity I looked on Ebay to see what is available today. The lower cost unit I saw was made out of steel and aluminum, a much needed improvement.
