Hi Guys, need to bore out and resleeve a casting so I made this to hopefully complete the task.
2 to 1 ratio spiral bevel gears with 3 MT spindle running in an oil bath.
Mill Drill to HBM.
Re: Mill Drill to HBM.
Very ingenious. With a standard taper, it will have future uses too.
Finally found a an advantage of a round column mill drill tramming is a breeze, just rotate the mill head on the column to tram.
I'd sure agree with Russ Armscor, very impressive.
