Mill Drill to HBM.
armscor 1
Mill Drill to HBM.
Post by armscor 1 »
Hi Guys, need to bore out and resleeve a casting so I made this to hopefully complete the task.
2 to 1 ratio spiral bevel gears with 3 MT spindle running in an oil bath.
Russ Hanscom
Re: Mill Drill to HBM.
Post by Russ Hanscom »
Very ingenious. With a standard taper, it will have future uses too.
armscor 1
Post by armscor 1 »
Finally found a an advantage of a round column mill drill tramming is a breeze, just rotate the mill head on the column to tram.
pete
Post by pete »
I'd sure agree with Russ Armscor, very impressive.
