Opinion on Rong Fu RF-400HS Mill Drill
Gary Armitstead
Re: Opinion on Rong Fu RF-400HS Mill Drill
Post by Gary Armitstead »
I have to agree with the comment above......This is a wildly overpriced drill press!
And I don't care what "Fong Ru" says, this is definitely NOT a mill/drill. A drill press and a mill/drill are completely different machines.
In my opinion, find a good used mill/drill and spend less than $1700. I'm a retired die sinker and over 55 years in the trade. I operated milling machines worth 100's of thousand's of dollars machining cavities in die steel. But for my home shop, I purchased an Enco mill/drill in 1981 and have built a couple of 1/8th scale steam locomotives with it and quite a few electric locos and rolling stock. Many say that mill/drills are incapable of accurate work. Nonsense, it's the person turning the handles that is not able to do the accurate work! JMHO.
Gary Armitstead
Burbank, CA
Member LALS since 1980
Member Goleta Valley Railroad Club 1980-1993
Gary Armitstead wrote: Tue Dec 22, 2020 4:03 pm Many say that mill/drills are incapable of accurate work. Nonsense, it's the person turning the handles that is not able to do the accurate work! JMHO.
And a valid one!
It isn't the machine, but the individual at the handles who determines what can and can't be done, and at what level of precision, within reason, of course. Everyone should keep in mind that mills are NOT jig borers, so tight tolerances (± .001" and below) become quite the challenge.
Like you, Art Crisp built a beautiful Pacific with a mill/drill. Art, now deceased, worked as a die maker.
Backwaterdogs
Post by Backwaterdogs »
Ok thanks everyone!
This was the kind of feed back I was really needing.
This dril looked heavy duty and reasonably clean, so to my novice eye, appeared to be a good deal.
will keep looking.
I do need a drill press and found an old craftsman (american made years ago) that I'll try and buy for 300 or less and keep my eyes open for a deal on a real mill.
Post by NP317 »
kl7sg wrote: Tue Dec 22, 2020 11:35 am They do make MT-3 tool holders.
If you need to mill, you can get a X - Y milling vise that will work ok on this machine.
The milling vises of this type have limited x -y travel.
I cannot imagine a round column drill press holding an x-y table stationary for milling.
Tool Junkie
Post by Tool Junkie »
For a few hundred dollars more than the price you quoted, you could buy a true Mill/Drill that would do everything that drill press will, and light milling too.
I used one for years until I could afford a REAL mill, and I did some very big jobs with it too. You just have learn the machines limitations, and work around them.
Don't know where those partial posts came from. :?: :?: :?:
Both deleted by moderator
kl7sg
Post by kl7sg »
NP317 wrote: Tue Dec 22, 2020 9:51 pm
Yeah, it would be marginal.
I guess if a guy took light cuts it would work.
Anyway, it looks like he is going to get a real mill.
Have a nice day,
Mike
Backwaterdogs
yep..thanks all!
Im passing on this drill and am looking for a real mill. Lots of options that all look to be pretty much the exact same mill (grizzly, dayton, jet) in that 2k price range.
they are all bench top type of machines.
I have the room for a real bridgeport and I missed a great deal on a very nice one for $3k when I first started looking, it was a steal..but I missed it.
keeping any eye out! thanks all!
