Many years ago I came up with a simple power feed arrangement for the tailstock on my 9" South Bend when drilling, tapping, etc.
I got a two piece clamping shaft collar with an ID the same size as my tailstock spindle. Then I made a forked bracket that engaged the shaft collar as shown in the photo. Bingo, I had a power tailstock feed. Just slightly loosen the tailstock clamp and let the carriage pull it along at the desired feed rate.
Easy Power Tailstock Feed
Re: Easy Power Tailstock Feed
Very good.
